Results 1 to 13 of 37
    Chicago
    Bosch's new air cooled residential heat pumps
    I just went to a promotional seminar on Bosch's new air cooled heat pumps, and it looks like a pretty unique product. Our supplier hasn't even got them in stock yet, so I've yet to see one run. They say the inverter will work with ANY TXV coil, and needs no sensor or communication of any type with the indoor equipment - it modulates solely off of the suction temp and pressure. Lots of other cool unique features, but at this point I'm just looking for anyone who has actually installed one to get their take.
    Jun 2012
    Northern NV
    me too. Like the idea.
    If it's anything like their clothes washers, it'll be a winner. I have a 14 year old Kenmore HE3t washer, but if you look at it closely, it's a Bosch made in Germany. A couple years ago my wife yanked the locked door open, and broke the safety latch. it wasn't available from anyone. Called Bosch USA, told the guy my problem, he laughed and ask if I got the part would I be able to repair it. He then got my info, I figured I'd never hear from them. A couple days later the safety latch arrived no charge!
    I only have to make it work till I retire.
  4. Likes DavidDeBord liked this post
  5. #4
    From what I hear, it's Midea made in China so probably won't do like the wash machine
  6. Likes DavidDeBord liked this post
  7. #5
    Chicago
    I can't remember who makes the cabinet, it might be Medea, but I do remember they said that it has a Mitsubishi inverter with a crazy number of real speeds to modulate from. I think they tried to get domestic manufacturers to make it, but they couldn't find anyone willing because it has too much potential to kill sales of their own modulating units.
    Every other inverter driven unit I've installed is 100% proprietary compatibility only - indoor, outdoor and controls all must match or no go. The Bosch unit is compatible with anything, as long as it's a TXV coil. Single speed PSC fan - no problem. A/C only application has two wire low voltage connection, heat pump four. It doesn't communicate in any other way and it doesn't care where the fan speed is, all modulation is done based on suction temp and pressure.
    The control board has minimal adjustments, the main one is what temp you want the suction to return at: 37f or 47f. It has a 3 digit trouble code reader, but you can only display the codes once and then they disappear. They said they didn't include memory because they wanted to keep the cost down of the unit, and from the preliminary number our supplier gave us, they did a good job of that.
    It only comes in two sizes, 3 tons and 5 tons. The idea is that if you have a 2 ton application, just flip some dip switches and limit the capacity. What's really surprising is how cheap it is. I'm not going to start listing prices here, but when comparing it to any domestic unitary manufacturers modulating heat pumps, its no contest. I'm an American Standard dealer, and it was even cheaper than any of their two stage cooling only scroll condensers (in any size)
    I'm not trying to sell these units (except maybe to my own customers) but I was just looking for someone who might have one of these systems running in the field. For all I know it may turn out to be the biggest piece of crap ever, but on paper it looks pretty freakin incredible. I bought the demo unit they had and am waiting on their coil to be delivered so I can get a matched system with an AHRI rating that will qualify for our local utility rebate. Would love to hear from anyone with more info on it.
  8. Likes skwoodwiva2, Juan Madera, DavidDeBord liked this post
  9. #6
    May 2017
    R.E. Michel is caring them. I have the tech number and will be calling with a slew of questions. Just saw the unit to day. 4/15/2017
  10. #7
    May 2017
    Fort Worth, TX
    We just had our old 4-ton AC replaced with a Bosch BOVA 60 heatpump and BVA-48WN1-M18 air handler. As mentioned above, one of the curious things Bosch did is rather then making separate 2 and 4 ton units, the 3 and 5 ton units have a jumper cable that you can cut to limit the capacity.
    When the installer put in the unit he called tech support and they said to hold off on cutting the jumper, leaving it as a 5-ton condenser unit and a 4-ton air handler. Could this create problems down the road? What are the consequences of having an over-sized condensing unit? Since the compressor is inverter driven (inverter driven rotary compressor from Mitsubishi, according to the product specs), does it matter?
    Also, the product brochure states that "The system along with an appropriate thermostat can learn your preferences, and adjust the output capacity to match your ideal temperature levels". However the wiring connections for the thermostat doesn't seem to have any additional wires for modifying fan speed. The blower fan has 3 speeds that you can set with a manual switch, so I'm not sure how the capacity could possibly be adjusted by a thermostat.
    All in all, it's an impressive and clever system. One feature that actually made it ideal for us is that the BOVA condensing unit is only 29x29 inches. As there was only six feet between the house and neighboring retaining wall most other condensing units essentially blocked access to the back yard gate. The Bosch was the only high SEER unit that fit.
  11. Likes DavidDeBord liked this post
  12. #8
    Aug 2009
    Beatrice, NE
    Seems funny that near as I know they have yet to manufacture a WSHP that is inverter driven which I know they have WSHP but I didn't know they had air source anything.
  13. Likes DavidDeBord liked this post
  14. #9
    Should not be a problem. The outdoor unit monitors the vapor line pressure and temp, and throttles down as needed.
  15. Likes Greg Lykens liked this post
  16. #10
    May 2017
    Haven't seen these but agree with others...the Bosch appliances I have had are also the very best appliances I have had.
  17. #11
    Jun 2012
    Northern NV
    I mentioned to the rep that this might be a good fit for zoning with air handlers. Two air handlers of less than 6 tons and use a LLS off the thermostat. Let outside unit run as a pump down. He said it should work, but was not approved (yet) The 5 ton will do 110% of rating apparently.... Or two 2 ton coils with the 3 ton unit... With some diversity of load the efficiency should be extraordinary.
  18. Likes Greg Lykens, DavidDeBord liked this post
  19. #12
    Dec 2012
    columbus, OH
    Củious how decreasing câpacity and nót fan speed could effect humidity removal?
    Sent from my SM-S320VL using Tapatalk
  20. Likes DavidDeBord liked this post
  21. #13
    May 2017
    Fort Worth, TX
    That's good to hear and it makes sense given that such a feature is one of the selling points of an inverter-driven compressor. It makes you wonder what is the purpose of cutting the jumper cable to limit capacity in the first place.
    Quote Originally Posted by Core_d View Post
    Could it be longer run times to remove more humidity?
    The other selling point is that it's much quieter on average than other units. I've gone outside a couple of times just to make sure it's running alright, and it sits right below one of the bedroom windows.
  22. Likes DavidDeBord liked this post
