Page 3 of 3 FirstFirst 123
Results 27 to 34 of 34
Thread: Digi Cool?
  1. #27
    Jun 2008
    Michigan
    Quote Originally Posted by ptemko View Post
    The only set I have seen in the wholesalers around here is the Yellow Jacket version. The only 2 refrigerants I use are R22 and R410A. I think that 90% of my calls are still R22 so I think I will pick up the Yellow Jacket set this spring. I have read all the info on the digi cools but have never seen any around here. I also don't want to put out that type of money on 2 sets for the 2 refrigerants.
    http://hvac-talk.com/vbb/showthread....light=digicool
  2. #28
    Toledo, Ohio, United States
    Twilli is very happy with his YJ
    No Heat No Cool You need Action Fast
  3. #29
    mass
    I have only had the 1250 for a couple of weeks. They have been easy to use and built well. Since I do not plan on using them to pull a vacuum I just put them on a standard YJ manifold. It makes them a little lighter and less cumbersome.
  4. #30
    N.E. KS
    Are there a pair of digital guages that read the temp of the gas without addtional clamp on probes to calculate sh and sc? That is the only reason I was wanting to get a pair.
    Some people know the cost of everything but the value of nothing.
  5. #31
    Quote Originally Posted by mdharris68 View Post
    You need to rethink your question. How would you calculate sub cooling when taking pressure at discharge service valve and calculating subcooling?
  6. #32
    N.E. KS
    Quote Originally Posted by Reeferman View Post
    90% of the equipment I touch has an access valve in the liquid side of the system. I avoid discharge port's if at all possible, usually have to fix leaks there though.
  7. #33
    burlington county n.j.
    gas is not going through the guages, how is it going to measure temp?????
  8. #34
    New England
    do they just stop at 30" of mercury? if not how low does it go?
    "Continuous effort - not strength or intelligence - is the key to unlocking our potential"
    Winston Churchill
Tags for this Thread
