Results 1 to 9 of 9
02-01-2009, 02:25 PM #1
- Feb 2009
- 5
HELP with Trane XR80 fault codes -NOT DIY!!!
This is NOT a DIY question. I am a professional contractor C.E.T. (Canada, Certified Engineering Technologist). I just don't have these Trane codes in my back pocket and the local Trane distributor is closed today. Probably getting ready for the Super Bowl.
Need help with the fault codes for a Trane XR80, specifically code 21. This furnace is in the home of an older relative and I don't want them to remove the blower door to read the codes in case they don't get it back on properly before I get there.
02-01-2009, 02:59 PM #2
There are several models called XR80. I don't see any code 21 in the one I looked at. Get your post count up and apply for pro status. Then you will get better answers.
Remember, Air Conditioning begins with AIR.
02-01-2009, 03:15 PM #3
I thought the basic description of the codes were printed on the wiring diagram inside the service door on the furnace.
That board might be manufacturer by White Rodgers (my XV80 is). On my Carrier Weathermaker I used to have, I think 21 was either flame roll-out or flame sensor fault or it was a pressure switch or auxillary dafety switch fault.
I found the fault codes we of limited use because what might be a pressure switch could also be a bad board a blocked flue or a problem with the ID fan.
But that's just my expereince troubleshooting my old furnace and I'm not a pro, so take it with a gran of salt. Althouhg I work on and troubleshoot industrial equipment and control systems, but not as a service tech.
I wouldn't get too hung up on the fault code. I suspect HVAC techs were troubleshooting furnaces that just used relay logic only long before they had a little red LED.
02-01-2009, 03:22 PM #4
- Jan 2009
- 8
There are no codes like that for that furnace.Hope this helps.
2 flashes-Systemm lock out
3 flashes-Pressure switch stuck open or closed
4 flashes-Open high temp. limit switch
5 flashes-Flame sensed without gas valve
6 flashes-115 volt polarity reversed
7 flashes-Gas valve circuit error
8 flashes-Low milivolt signal at flame sensing rod
02-01-2009, 03:27 PM #5
- Feb 2009
- 5
Thanks for your reply. From your list of codes, it sounds like he probably meant code 3 rather than codes 2 and 1.
02-01-2009, 03:28 PM #6
Banned
- Dec 2006
- Middle Tennessee
- 11,347
03-09-2009, 10:58 AM #7
- Mar 2009
- 4
TRANE XR80 Furnace
3- Red Light Flashes. - Pressure Switch Error.
I am having a hard time finding any information on further trouble-shooting this problem.
Do you guys have any hints ?
Thanks ahead of time.
03-09-2009, 11:04 AM #8
03-09-2009, 11:20 AM #9
Sorry, this is not a DIY site.
Please read Site Rules
Thread closed.
