Results 1 to 4 of 4
    Mar 2017
    supply air fan in residential application -- AHU or no ?
    Just wondering if you guys use a supply air (inline fan?)_if so what and why ?
    Also, are they hooked up to the AHU or no in most of your applications ?
    thanks!
    rt
    Athens, Ohio
    Quote Originally Posted by richtree View Post
    thanks!
    rt
    Your questions are not clear. There has to be a blower, either in an air handler or in a furnace.
    If you are asking about an inline booster fan - I refuse to use them. They don't solve the problem, then they get noisy in a few years, and when they fail in a few years more, they block air flow.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Mar 2017
    Quote Originally Posted by kdean1 View Post
    If 62.2 is adopted for balanced ventilation it doesn't require hookup to AHU... just a lot of filter changes or cleanings
    Athens, Ohio
    Now you have introduced another unknown. What is 62.2?
