Thread: I lectric heat.
    Oct 2016
    midwest
    I lectric heat.
    Why would an electric duct heater need a 24v relay on incoming control voltage? Had 23v to relay but didn't energize contractor.
    Apr 2010
    Tecumseh Valley
    Don't know for sure without a model number, but that's a common way to ensure that the heater doesn't come on without the fan signal.
    There's two common ways, an actual airflow switch in the heater, which won't turn on the heat unless air is actually moving through, and then the kind where the heating call is routed through a relay that's controlled by the fan signal. That sounds like what you got. The drawback to this approach is that it only keeps the heat from coming on without a call for fan, doesn't help with something like a broken belt or severely clogged filters.
  3. Likes hvacron liked this post
  4. #3
    Oct 2016
    midwest
    Quote Originally Posted by CHAINIK View Post
    It was controlled by a fan signal. Which wasnt allowing it to turn on. Had 2-a44 belts that were on there way out. Also was connected to Honeywell control system that maintenance guy played around with and turned signal off to that heater. Not allowing heater to turn on
