Results 1 to 7 of 7
Thread: McQuay low disharge temp fault
    Nov 2005
    McQuay with this alarm tripping about every two week or so with this alarm. Checked econ minimum position and osa lock out for mech cooling. Has any one ran into this. This unit is a maverick and has been a issue from day one.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Indiana
    more info on what type of unit it is....McQuay makes a wide variety of equipment
    Outside The Motor City
    Quote Originally Posted by allstar08 View Post
    If it an RPS unit you post yours I'll Post mine.
    Wichita Ks
    default setting is 40 degrees. it is adjustable from 20-50. is there heat in the unit? for some reason the discharge air is getting below the setting. check all settings.
    Wat type of unit?
    Nov 2005
    I wish I had more info right now. It is 40 ton vav unit w/o and heat source. Maverick was written on the manual. I was there on a different problem a month or so ago. I am posting this for a fellow tech. This happens when it is colder outside, so I think it is econ related, but it doesn't happen all the time. This unit is not even a year old yet.
    Wichita Ks
    it is a mps unit
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
