    Apr 2004
    Strange Oil furnace call
    So I get a call from a customer who says they have an oil leak in their utility sink in the basement??? So I go to take a look and find this ....
    Leaking flare fitting on oil line leaks oil into condensate pump ....pump then pumps it into the sink. Notice in the pic the 3/8 vinyl tubing full of #2 heating oil.
    Unit is less than a year old and look at the condensation on the flue. Inspected chimney cap no problems there. Stack temp @ 383 and draft @ -.21. Installed high fire nozzle for the furnace and had to install a 2nd draft regulator to get the draft under control. Guess thats what happens when you take the furnace out of the box and turn it on without adjustments.
    Apr 2008
    God, I hope my company didn't do that one.
    Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
    Jul 2005
    North Central Ontario Canada
    Yeah thats a nice certified oil shut off valve
    Here's your sign...
