Page 1 of 4 1234 LastLast
Results 1 to 13 of 42
    Here's some pics of my new Amana HP &
    the accidental damage to the old AH closet
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	13942   Click image for larger version.
ID:	13952   Click image for larger version.
ID:	13962   Click image for larger version.
ID:	13972   Click image for larger version.
ID:	13982   Click image for larger version.
ID:	13992   Click image for larger version.
    Is that an ASZ16 or 14?
    ASZ-18 Baby!
    Quote Originally Posted by badtlc View Post
    Whisper quiet, luv it
    Keokuk, IA
    Pretty minor cosmetic damage. Not worth the trouble IMO. Maybe there's a better way to fix it, but personally, I'd just fill it it with some paintable window caulk or wood putty and then paint it. 20 minutes worth of work at most.
    N.E. Ok.
    Nice unit.
    Disconnect is too far behind unit.
    Is that you by the unit .. j/k
    DC Metro area
    As above, I would get some spackle or a similar gap filler and just be done with it. They come in small containers at Home Depot.
    LMAO
    Quote Originally Posted by captube View Post
    Nice unit.
    No, mullets aren't my thang, yet................
    Jun 2008
    va
    It looks like an Armstrong unit.
    Where are the risers?
    Mar 2002
    Concord, CA
    The "It happens." response your contractor gave you was pretty flippant. That sort of damage doesn't happen if you take a half minute to fold a cloth tarp over and lay it over the trim as you're shimmying the new and old units around. Frankly you have to be a pretty obtuse installer not to think about that... in my opinion.
    If that just happened out in the open, what just happened that you don't know about?
    Anywho, it's a question of picking your battles.
    This is prolly not one Im gonna fight
    Quote Originally Posted by Irascible View Post
    perhaps he'll come off the 1 year maintenance
    Jersey
    sorry you are missing the clamps for the seal tight, seal tight should be clamped less then 1 foot from the disconnect, The whip could of been ran neater.
    just an opinion.
    OK unit.
    I saw you had Trane on the van why not Trane?
    Life is too short to give a SH*T about the small things, Thing could always be worst!
    Karma is great!
    south louisiana
    "Disconnect is too far behind unit."
    my thought also! should be to one side or another.
    if (god forbid) the unit should ever catch on fire
    that you can't safely reach over the unit.
    @ the heating closet,
    I'd just wood putty, sand and repaint.
    best of luck.
    Oct 2008
    SoCal
    Sorry but the damage isn't acceptable unless you don't really care. it's lazy ness to not protect stuff like that, and worse not to tell you it will be fixed, just my $.02...
