Results 1 to 12 of 12
    Aug 2008
    Houston Texas
    Pipe clamp thermocouple for Fluke 902
    I'm looking for a pipe clamp thermocouple for my 902. All the ones I've seen use the type K plug, and my 902 only has the banana plugs. Do I have to get an adapter, or is there a thermocoupled that will work with my unit? Thanks, as always!
    In the work truck
    fluke sells a plug that will work as an adapter for the K type... let me find it
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    In the work truck
    Oct 2008
    New Jersey
    http://www.drillspot.com/products/72...couple_Adapter
    here ya go, this is what you need. Beat ya to it Pascone10
    Maybe not lmao!!!
    I dont install leaks, i just fix em
    Sig line removed by Admin*
    Lets see if this gets removed..............
    In the work truck
    Quote Originally Posted by KLEINman View Post
    Maybe not lmao!!!
    not fast enough....
    maybe next time grasshopper!
    Oct 2008
    New Jersey
    Quote Originally Posted by Pascone10 View Post
    not fast enough....
    We posted at the same time smarta@# lol, the website just like you better
    SF Bay Area
    Hit an electronics store or order from Omega and the make your own. Pick up a cheap ratcheting plastic clamp from a home improvement store and make your own.
    Your a service guy, use those "field skills".
    Aug 2008
    Houston Texas
    Quote Originally Posted by HeatXfer View Post
    I'd rather have the flexibility that the adapter will give me, as far as using different types and brands of K type probes.
    Oct 2008
    New Jersey
    Quote Originally Posted by troywoodall View Post
    Very true, get yourself either a fluke pipe clamp or another brand if you dont already have one.
    Jun 2007
    Greenville,North Carolina
    My adapter came with my Fluke 16,just don't use it that often.I rather use my 52 II
    Look to the past to learn;look forward to live.
    Coach Dean E. Smith
    I have both the Fluke 80pk-8 and a Fieldpiece pipe clamp. I have tested them side-by-side and see no real accuracy difference between the two.
    Both have an application because one fits where the other won't.
    I've done the make-a-clamp trick, too, but purpose built instruments work better. Tested that, too.
    Aug 2008
    Houston Texas
    Found this adapter on Ebay. Looks a little fragile than the Fluke, but it's less than half the price and looks like it fits a bunch of other arrangements as well.>http://cgi.ebay.com/K-Thermocouple-A...QQcmdZViewItem
