Results 1 to 13 of 38
Thread: Quick 80%er
    Jan 2011
    Quick 80%er
    New system. Turned out pretty nice. Onto the next..
  2. Likes HeatenCoolair, Snaple4 liked this post
  3. #2
    Mar 2014
    Grand Blanc
    Looks awesome man! Keep up the good work.
  4. #3
    Sep 2012
    Cincinnati
    Someone understands airflow. I'm still learning, but I see the wisdom in the design at the top and bottom of that return drop.
    Sent from my iPad using Tapatalk
  5. Likes Mardigras liked this post
  6. #4
    Oct 2014
    Minnesota
    Nice work. Have you every thought of making small mistakes on purpose in order to test us? I assume that the filter acces is by the water heater, if not, that is a neat door.
  7. #5
    May 2015
    KS
    Nice work. Our inspector is starting to require drain pans and float switches even in unfinished basement. Even when the floor drain is close by.
  8. #6
    Athens, Ohio
    Nice work!
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  9. #7
    Jul 2009
    Columbia, MD
    Good work.
    Now all you need is some white tape and cork
  10. #8
    Dec 2012
    columbus, OH
    Looks good on the pad
    Sent from my SM-G550T2 using Tapatalk
  11. #9
    Sep 2011
    In the truck
    Does the pad help reduce vibration at all?
    UA Local 562
  12. #10
    Sep 2014
    NW Arkansas
    Looks good. Really like how you were able to redo the return. Did you take pre/post static by any chance?
    Is the flue pipe horizontal?
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  13. #11
    Feb 2011
    Georgia
    Quote Originally Posted by ckelley3 View Post
    you gotta be the air and blow yourself!
  14. #12
    A+++ job looks grate.
    do you know anything about how reliable or not reliable the whirlpool water heaters are?
    my land lord is using them now instead of state water heaters.
  15. #13
    Mar 2013
    Port St. Lucie, Fl
    Quote Originally Posted by chrisevansac View Post
    If I could "be the air" I don't think I'd ever leave the house!
    Sent from my SCH-I545 using Tapatalk
