Results 1 to 14 of 14
Thread: MR. SLIM blowing humid air, any help?
    Jul 2016
    I have a MR. slim MS-A12WA, it blows air 24/7, either cold air but when not cold air it blows regular air, and lately it's been very humid, the room, which does have exterior french doors, has been getting 60% humid.
    When i turn off the mr. slim, it gets less humid but also warmer. Any way for it to blow less humid? Thanks.
    Southold, NY
    A/C's do not add moisture.
    The fans on minis run 24/7
    What is the Heat load where this 1-ton unit is located?
  3. Likes kdean1 liked this post.
  4. #3
    Jul 2016
    not sure about the 2nd part, its in a cabana pool house off the main house, there are double french doors to get in but i am guessing part of the reason is outside proximity, but damn, it just gets so humid in here lol. i bought a humidity sensor, main house is 35%, guest house is 55-65%
  5. #4
    Southold, NY
    How big is this pool house?
  6. #5
    Jul 2016
    it's either 14X11 or 17X11 also has a full bath and closet attached.
  7. #6
    Southold, NY
    That unit is 3 - 5 times too large.
    Get a dehumidifier
  8. Likes kdean1 liked this post.
  9. #7
    Jul 2016
    Get a dehumidifier
    I actually do have a dehumidifier, some zenith unit but its so damn loud. i can get it down to 40% humidity, but it ends up going back to 60%, there is also a vent from the main house ac, when that is blowing the humidity drops about 8%
  10. #8
    Southold, NY
    Who sized 12,000 btu's for that small of a room?
  11. #9
    Jul 2016
    I have no clue, it was preexisting.
  12. #10
    Heated pool adds a lot of load.
    Quote Originally Posted by justinnum1 View Post
    55 to 60% RH for a pool house is not out of line. What temp are you maintaining in the pool house, and what temp are you maintaining the pool/water at.
  13. #11
    Jul 2016
    We dont use the heater for the pool but the room is near the pool.
    I held the humidity sensor right to the vent on the mr slim when it was just blowing regular air lightly, and it was over 60% humidity, thats part of the reason i think.
    also, noticed the filter was very dirty, looks like greyish white lint/dust... could that be contributing to the humidity?
  14. #12
    Southold, NY
    Do not measure the discharge air. Just an average of the room is fine.
  15. Likes kdean1 liked this post.
  16. #13
    Jul 2016
    ok. i have the unit off right now, and im getting 51% humidity. Temp 75.
  17. #14
    Prata di Pordenone Italy
    Should have a 30 degree delta t on the mini split if not it's a problem
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
