Results 1 to 13 of 34
Thread: Chimney cap
    Jul 2014
    Chimney cap
    Found this a few months ago
    Red face Chimney Cap Picture Fixed
    Much betterName:  IMG_1546.jpg
  3. Likes VTP99 liked this post
  4. #3
    In my area the owner would be told to re point the chimney or tare it down.
    that is a death trap waiting to fall on someone.
  5. Likes shavedneon liked this post
  6. #4
    Feb 2014
    Jesus.....
  7. #5
    Jan 2012
    Broomall, PA
    Why didnt they just use the interlocking blocks that people use for patios? That's going to fall and kill someone, if the CO doesn't kill them on the inside.
    "Sometimes what's right is what's left after you do everything wrong"--Robin Williams
  8. #6
    Jan 2010
    They have the stacking part down but just haven't master the mortaring part yet.
  9. Likes tmt liked this post
  10. #7
    Sep 2011
    In the truck
    Oh boy..
    UA Local 562
  11. #8
    There's no joint space - are you sure it's not just stacked brick?
    If so it would be easy to fix - you could just gorilla glue it together.
    PHM
    Quote Originally Posted by pctech View Post
    PHM
  12. Likes ckartson liked this post
  13. #9
    Jan 2014
    New England
    3rd world repair in a 1st world country.
  14. #10
    Oct 2014
    duct tape
  15. #11
    S.E. Pa
    Not any worst than a million chimneys in Philly. We just relined one that caused PGW( ulitity) to Red Tag a gas furnace and water heater that were backdrafting. Chimney was lined with unlisted rigid stainless steel--sorta. You see, there is a LOT of 'roll your own' chimney liner in Philly. Contractors roll unlisted pipe, both galvy and ss, and install with electroplated screws. Those screws rust out and the joint fails leading to pipe dislodging and backdrafting. Sometimes they put it in male up, some down. In this case, they did it both. At one point, they spliced the liner---with cheap foil tape. Another section was ovalized, which reduces the flow capacity. Then it crossed over from one brick flue into an adjacent one that lead to a sealed off fireplace. From there, it turned, rubbed past some charred wood before re-entering the same flue it started in. The breeching was jammed in tight next to the coil so inspection or service were impossible. We had to open the fireplace and the outside wall in the alley to correct it with a Ul listed one piece ss liner. Now he knows why my original bid was three times that of the closest competitor. Oh, btw, the exterior chimney was covered with roll roofing. Yes, combustible roll roofing. We have to cut it away, parge the chimney with stucco mix, rebuild the top three courses corbelling them in then set a precast crown for the ss top plate and rain cap to rest on.
  16. #12
    May 2015
    KS
    Nothing a 4' tall custom cap wouldn't fix.
  17. #13
    where is it gonna fall? on that chitty azz roof and affect no one but the people under it. they need a wake up call
