Page 1 of 4 1234 LastLast
Results 1 to 13 of 49
Thread: Poor brazing
    Jun 2009
    DFW, TX
    Poor brazing
    I look forward to a day when people learn that a proper braze joint is NOT when you stick a bead of silfoss around the outside of the joint.
Size:  69.8 KBName:  540_1484877560637.jpeg
    Seriously? 😕 I fixed that one a few weeks ago but forgot to get a pic.
    And then today had this one that was leaking terribly.Name:  548_1484877565152.jpeg
    Wow. Here's after my repair:
Size:  75.6 KBName:  549_1484877568295.jpeg
    I'm at a loss for words. This is happening too frequently.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  2. Likes mkovack liked this post
  3. #2
    Nov 2014
    Portland, Oregon, United States
    A good braze should not look like a tumor.
    Sent from my SM-G935T using Tapatalk
  4. #3
    Jun 2016
  5. Likes trippintl0, armandomartinez liked this post
  6. #4
    Jul 2013
    Richmond, VA
    Looks like that line set has herpes. Don't touch it!
  7. Likes STEVEusaPA, tmt, 2sac, jnewton, CHILLERSVCMAN liked this post
  8. #5
    Mar 2013
    Billington Heights, NY
    I'll put this up for shats n giggles. I did this. A 3/4" water line with a 1/4" hole. It was still drizzling water... but it's plugged.
    Every time I go back for something I see that it doesnt leak but still think "what a hack".
    Sent via ESP...
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
  9. Likes HeatenCoolair liked this post
  10. #6
    Apr 2005
    Australia : Queensland
    How can you think that's not going to leak then walk away ?
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
  11. #7
    Nov 2011
    East Side
    Quote Originally Posted by HVAC_Marc View Post
    Sent via ESP...
    So I guess I shouldn't tell you that I've had water lines freeze and split. Rather than cut them out and solder in couplings, I've pinched them shut and brazed over the crack!
  12. Likes HVAC_Marc, knave, CHILLERSVCMAN liked this post
  13. #8
    Oct 2007
    Austin Texas
    Quote Originally Posted by 71CHOPS View Post
    That would make two of us.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
  14. Likes ga-hvac-tech, JohninJoliet liked this post
  15. #9
    Mar 2013
    Quote Originally Posted by fridg View Post
    Because 15% silver solder is rated in the thousands of psi, and it only has 65 psi on it. Plus, it hasnt leaked in years and the pipe will rot before the fix will.
  16. #10
    Dec 2014
    midwest
    Quote Originally Posted by John Culpepper View Post
    3 of us!
    Sent from my SM-G930V using Tapatalk
  17. Likes tmt liked this post
  18. #11
    Mar 2013
    it's the best way to do it. stronger than a coupling.
  19. #12
    Cincinnati, Oh
    Not to be weird here, but I thought you weren't supposed to use braze because it would "contaminate" the water supply. Seriously, just asking.
    "Just get it done son."
    Dad adjusted
  20. #13
    Sep 2014
    NW Arkansas
    Quote Originally Posted by hvacvegas View Post
    I thought the same thing unless you are flowing nitrogen....
    Sent from my SAMSUNG-SM-G891A using Tapatalk
