    Dec 2016
    Confused Munchkin 399M issue
    One of our Munchkin 399M boilers runs continuously and never gets above 150 degrees. Fan speed 8,000 rpm, condensate drain was partially plugged but has been cleared and no error codes. Should I be looking at the circuit board which modulates the fire rate or a dirty heat exchanger?
    Mar 2013
    Billington Heights, NY
    is this a new issue? what has changed since it worked correctly last?
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Glennac - Failed my biology test today: They asked, "What is commonly found in cells?" Apparently "BL*** people" wasn't the correct answer.
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Dec 2016
    It had been cycling great achieving 180 degrees without issue. I believe its the circuit board so I unplugged the air switch and it kept running with no error codes.
    Jun 2012
    Northern NV
    Fireside of the heat exchanger on these can get plugged up and having had a plugged condensate trap would lead me to suggest you find a service tech that has had experience with doing this particular service.
