    Twin Cities, MN
    Hunt for fireplace insert
    We have a older brick and block fireplace (late 70's) and are the hunt for a fire place insert. To keep it short and sweet, is there a fireplace insert that uses outside air for combustion? Seams like this would be the best way to get the most out of a insert.
    Yes, and yes
    S.E. Pa
    Cool which fuel?
    Stop in at your nearest FireSide Hearth & Home store such as the one in Eagan. Check out the Heat&Glo Firebrick gas inserts or Quad pellet and wood inserts.
    You can also check out www.fireplaces.com
    HTH,
