Results 1 to 13 of 16
Thread: part needed
    Dec 2016
    part needed
    I need a mercury flame switch for a comfortec model CDV36 part number GF7571
    May 2014
    Bay Area California
    Dec 2016
    Do you know if there is a retrofit for the controller to make it work.
  4. Likes refrepairman liked this post
  5. #4
    Caledonia WI
    BBeerme, check out this turd I have set aside for one of my customers boilers.
    I just changed out the whole gas train on a boiler with the mercury switch the OP needs Friday it just so happens to be the same customer.
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
  6. #5
    May 2014
    Bay Area California
    LOL, Small wonders will never cease.
    Had a call on an old BDP gas pack a few weeks ago. No heat. Had a funky glow coil I haven't seen for years; it was open. So I know I needed one of those. And I couldn't light the pilot with my Turbo Torch. But it also had one of those mercury probes for the flame sensor. You have to pull the whole burner assembly out just to get to that stuff.
    Gave a proposal to the customer for four hours to pull the burner bar, re-plumb it exterior to the unit, then tell them what else was wrong with another proposal.
    Or they could buy a new unit. After all, it was over 40 years old!
    Pulled the blower and couldn't believe it when I saw how good of shape the heat exchanger was.
    But the customer got the hint and is going with a new unit. Smartest thing to do in this case.
    Quote Originally Posted by billg View Post
  7. #6
    Caledonia WI
    I think I have one of those coils, is it set in porcelain and mount on the pilot hood? I have nos parts from the 50s. I just ran out of the flat Honeywell power piles.
  8. #7
    May 2014
    Bay Area California
    Pretty sure that's the one. Can barely even see it with a mirror and flashlight. It pre-dates those popular pilot assemblies with the white, green, and yellow wires.
  9. #8
    Caledonia WI
    I love it when the converted boilers are all cemented shut and in order to light the pilot you have to open door and clean all the cement off and reseal it.
  10. #9
    May 2014
    Bay Area California
    Your latitude is somewhat north of me, I don't get that here. Any and all boilers I have ever seen run on natural gas from the factory.
    In fact, I really don't know a thing about oil fired boilers. Except that they run on oil. Regarding a converted boiler, not even in my realm of experience. But if I moved to where you are, I can promise you that I'd be a fast learner !!
  11. #10
    Caledonia WI
    It's not unusual for me to see 90+ year old boilers, first converted from coal to oil and then from oil to gas, the last one I changed out did still had stoker parts still under the oil tank and the timken oil conversion burner under the steps.
  12. #11
    Mar 2013
    Billington Heights, NY
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Glennac - Failed my biology test today: They asked, "What is commonly found in cells?" Apparently "BL*** people" wasn't the correct answer.
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
  13. #12
    May 2014
    Bay Area California
    So for the flat rate guys, that's like what, a thousand bucks to the customer ?
  14. #13
    Mar 2013
    Quote Originally Posted by BBeerme View Post
    dont know, but it'd be about double for my customers
  15. Likes BBeerme liked this post
