Results 14 to 26 of 37
    Fairfield county Connecticuit
    VS is the best way to go almost unlimited to what you gan do with them also go for
    R410A
    Nov 2001
    east kansas
    Quote Originally Posted by RoBoTeq View Post
    On variable speed furnaces, Y and O are jumpered, just like on Trane units.
    So???
    Does Y control ramping profiles or does O?
    You sure dance pretty.
    Can you set ramping profiles with dual fuel equipment, and will those ramping profiles be ignored in heat mode?
    Beware of advice given by some guy on the Internet.
    y ramps up for ac w for heat
    If you want to discuss how to set up the ramping profiles.
    Start a thread in the pro tech forum.
    Nov 2001
    east kansas
    Quote Originally Posted by Danimal535 View Post
    The question pertains to dual fuel applications.
    First stage heat will not give a W call. It gives a Y call.
    If Y controls ramping profiles and profile D is selected for humidity control in cooling, it will not provide the needed cfm for a first stage (Y) call for heating. It will provide 50% of full demand airflow for 1/2 min. Then 82% air flow for 7 1/2 min. In this time it is possible, and probable, for high pressure lock out.
    Nov 2001
    east kansas
    Are you talking to me?
    To anybody that wants to get indepth in the setting of the profiles, the wiring, and how its controlled.
    Thats technical enough, to merit being in the pro tech forum.
    Nov 2000
    Eastern PA
    Quote Originally Posted by Milk man View Post
    So???
    I have no idea what you are trying to prove here milkdud, but get it through your thick skull; there is no difference in the basic functions of any of the variable speed blowers on the market.
    I have no idea what it is you are getting at or what you don't understand and I have no intentions of getting into another one of your petty little debates in an open forum. Why don't you start another brand bashing thread on a pro forum if you think you know something to support your brand bashing. This is an open forum. Get a clue.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Nov 2000
    Eastern PA
    For crying out loud, you cannot be this dense. How about this; start a thread in the B&M forum
    OH! Sorry bout that! Your not knowing when to shut up did you in there too, didn't it?
    Nov 2001
    east kansas
    Hey RoBo, you forgot to quote this one. Or do you just not have an answer that you can spin?
    Is what I said a correct statement?
    Nov 2000
    Eastern PA
    You truly are just not very bright, are you?
    Nov 2001
    east kansas
    Your just going hurl insults instead of answer the question.
    Give me five minutes and this question will be in the tech forum for you not answer also.
    Wow, this thread turned intereting. So it seems that a VS air handler is recomended and a 2 stage compressor is not needed for a VS and probably not needed in my application since i live in VA. Besides getting a model # of the outside unit and air handler what else will help you guys help me make an informed decision. My backup heat is electric as well. The Lennox guy recommened the clean air system for $xxx as well. I think this was like buying underbody protection on a car. Not necessary. Thanks
