Results 1 to 13 of 30
    how many pounds of freon in condenser?
    I have a 3 ton 14 seer goodman condenser with about 15 of line set. The tech said my system is out of freon which sounds right since my ac is not working at all. he said he will be back monday or tuesday to charge it but since R22 is phased out it will be pricey. About how many pounds of freon would he need to charge my system? I am wondering so i dont get taken for a ride here. thanks
    Sep 2003
    Portland.OR
    not that much
    22 isnt that high priced. Just fix it!! Shop the price at a few shops if you want.
    Finding the leak is the most difficult part, often its the indoor coil thats gone south. Thats a BUNCH of bucks....
    the indoor coil is fine is was some bad brazing that had a slow leak he said but id still like to know this guy charges alot or over charges unknowing costumers i think.
    Nov 2008
    Colorado
    At the top of every page of every thread, it says no DIY and no pricing. You can call other companies for a quote, but nobody is going to answer that here.
    Clearwater, Fl
    would imagine you would be near 6 - 8 lbs refrigerant, then add in leak test, 2 trip charges, evacuation fee, new filter/drier, labor,and possibly a few other odds and ends,then you would have a complete cost = not cheap, but not as much as a new coil.
    Most contractors do not rip people off. My main complaint is that MOST contractors do not charge enough for the services that they perform.
    If people only focused on the important things in life there would be a shortage of fishing poles.
    Dec 2000
    phoenix, arizona
    look at the label, it will tell you how many pounds should be in the system. add some for testing. Most of the cost will be labor; normally difficult to find and repair a leak, sometime tech get lucky.
    Shop for reliable licensed contractor, majority are honest. stay away from deals you know it too good to be true.
    Decide what you want, decide what you are willing to exchange for it. Establish your priorities and go to work." H.L. Hunt
    "In order that people may be happy in their work, these three things are needed: They must be fit for it. They must not do too much of it. And they must have a sense of success in it." John uskin
    Quote Originally Posted by mario3252 View Post
    Did he find and repair the leak.
    The 3 ton 14 SEER R22 models, nominal operating charge is in excess of 13 pounds.
    Could be over 14, depending on indoor coil match up.
    Yes, it will cost a lot.
    More like he charges what he needs to make money.
    NW burbs of Detroit
    Why scare the customer in to price shopping?
    We are giving the HOs the impression we are over charging for our service.
    A red flag goes up when a contractor says "its going to be expensive" and they, the HO, are going to distrust the job wondering if they are being ripped a new one.
    Perfect example is Friday i got a call form my free YP listing. I usually ignore theses calls because they are almost always people looking for the best but wanting to pay the least.
    Blower was gone. I quoted her a price and the HO balked at first. I did not mention it was expensive. Just answered her when she asked how much a new furnace cost. Than she thought the blower was a bargain.
    Had I of sadi "Yeah it's expensive" she probably would have just paid the Call Charge and found someone who would make her feel more more comfortable
    with er decision to spend more money than she was willing too.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by forcryinoutloud View Post
    we used to baseline each (9 seer) ton requiring about 3 pounds per ton
    gone are those days, due to higher eficiency and bigger coils!
    Quote Originally Posted by hvaclover View Post
    I agree with most customers, parts are expensive.
    Over charging would be charging one customer more then another for the same identical part, for the same identical service.
    Expensive is a terrible word.
    But, I consider McDonald's expensive too.
    Northeast Ohio
    Costs are relative. If you don't trust your tech, why are you using his services? The charge of refrigerant is listed on the unit, that's how the tech knows how much to weigh in + xx amount over a given line length. All refrigerants are expensive, some more than others. I don't subscribe to fear selling tactics as far as this that or the other is more expensive, no longer made, gonna be phased out or any of the other crap. All you need is an up front amount for refrigerant per pound, service call, extra labor and additional parts. Should not be a mystery as far as what it will cost you. By the way, if it was completely empty as it most likely was, a new filter dryer should be added to be extra safe.
    DEM
    Northeast Ohio
    I dunno about expensive, I like the dollar menu thing. Now, I would agree that it's not all that great, but it is consistant
    DEM
    NW burbs of Detroit
    Exclamation
    "Over charging would be charging one customer more then another for the same identical part, for the same identical service."
    not what I meant. The verbiage we use has to be chosen carefully so as to keep the HO comfortable.
    A tech who uses wording like "Yeah, it's going to cost you" or "It is expensive" are just feeding the HOs distrust.
    By way of example I did not communicate any thing more then the price.
    Bare in mind this is a first time customer and I had not established a rapport
    with. When she finally reluctantly gave her consent I explained the benefits of the new motor as the old one was a shaded pole motor.
    By the time I left i had signed up for a tune up and a new digital stat.
    S I do believe communicating that it will be expensive will put a customer on guard.
    Even with regular customer whom I know will ok the job I do not use the that term "Expensive". It makes the tech sound like he is on the defensive.
