Results 1 to 11 of 11
    Dec 2008
    Is It Worth The Money?
    I am having a new 3000sf home built and I can choose to heat with two 90+ variable speed, 2 stage gas furnaces or a hydro air type set up using a condensing, high efficency, modulatong gas boiler and two variable speed air handelers for a huge amount of money more. Now the question is not which is the better system, it's is the hydro worth the huge price tag?
    No prices in post, or price questions allowed, Please read site rules, Thank you.
    Jun 2008
    Southeast Michigan
    If it's being built, why not go for radiant floor heat using the boiler? You'll be able to have lots of zones to maximize comfort in each room.
    Is it worth it to use a boiler to heat a coil in an airhandler? Nope, it's a waste in both install cost and fuel usage.
    BTW: might want to remove the dollar stuff before the mods ask you to and also review the site rules.
    Dec 2008
    Sorry, I missed that.
    The price for the radiant is also very very high.
    The boiler hydro is ok if your also getting an indirect water heater so you have a large hot water volume.
    Nov 2001
    Long Beach New York
    No.
    If you want comfort
    Leave the ducts for AC. Panel rads for heating.
    Jul 2001
    Gold Coast of Connecticut
    I would quote 2 Luxaire modulating furnaces and a high efficiency gas water heater. The modulating furnaces are the best for comfort. Spend the money on good air filtration, humidifiers and UV light.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Centeral Il.
    I use a water to water geothermal unit with an air handler. That way you get both AC and Infloor from one compressor unit.
    Feb 2007
    Great Lakes Region
    The furnace at 90% and a boiler at 90% is the same energy consumption. They will both be forced air, so the comfort is the same. The baseboard or radiant heat will give you more comfort but at a much higher price. your hot water usage is low so it is not a big factor. If it is only between furnace and boiler generated forced air than stick with a furnace. Initial cost and future maintenence costs will be much cheaper. If your thinking you would like to pay for the added comfort of radiant, and can afford it, you will be happier with the comfort level in the heating season
    SW FL
    Thumbs up Life Cycle Cost required
    Quote Originally Posted by Anthony NY View Post
    ... new 3000 sf home built
    ... heat with two 90+ variable speed, 2 stage gas furnaces
    ... or a hydro air type set up using a condensing, high efficency, modulating gas boiler and two Variable Speed air handlers for a huge amount of money more.
    1. Determine Life Cycle Cost = Initial + Operating + Maintenance Costs
    2. Factor in your Comfort
    I would review Heat Pump with gas furnace and Varialbe Speed air handlers
    Designer Dan
    I would price out
    a single zoned AC system with the boiler and indirect HWH with panel rads or high end baseboard. Where's the second 90+ furnace gonna go? In the attic? Not recommended.
