Results 1 to 12 of 12
01-17-2009, 02:11 PM #1
- Nov 2008
- 1,656
HD 16x25x1 paper frame furnace filters
Any suggestions on when to replace these, based on appearance or how bowed they become over time, or how well they pass light?
It seems to me someone made an embedded whistle for filters of this type that would start to whistle when the upstream and downstream pressure delta was enough. Anyone know of a company that makes these?
Thanks.
01-18-2009, 12:10 AM #2
Professional Member*
- Jul 2001
- Central MN and the Twin Cities
- 1,516
Just change them monthly.
Warning: Just because I am over the head injury doesn't mean I'm normal!
The day I stop learning.... I'm dead!
01-18-2009, 11:20 AM #3
- Nov 2008
- 1,656
01-18-2009, 12:32 PM #4
- Jun 2007
- The Twilight Zone
- 2,964
01-18-2009, 05:32 PM #5
every three months
01-19-2009, 12:35 PM #6
- Nov 2008
- 1,656
let me rephrase. . .
If they still look fine and are not bowed after 6 months and you can still sort of see through them, is there any reason to replace them? How 'bout after 12 months?
Do filters clog up even if they look perfectly OK?
01-19-2009, 01:26 PM #7
If your waiting until they bow, your waiting TOO long!
01-19-2009, 01:32 PM #8
New Guest
- Jan 2009
- 1
How do you post questions on this site?
01-19-2009, 01:33 PM #9
- Nov 2008
- 1,656
01-19-2009, 01:39 PM #10
- Nov 2008
- 1,656
Good.
So, bowing (regardless of appearance or being able to see through it) indicates resistance to air flow and so it must be clogging up?
Maybe somebody makes a furnace filter monitor based on pressure differential, light passing or the element being gradually bowed over time.
Is the ultimate pass/fail standard the upstream/downstream pressure ∆?
If I never replace a filter, the airflow will tend toward zero and the furnace high limit switch will open, yes?
01-19-2009, 01:46 PM #11
Honeywell makes a PD monitor.
01-19-2009, 01:48 PM #12
