Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 72
  1. #27
    Feb 2007
    Great Lakes Region
    Confused
    I really should stay out of this, but need to get some posts to get into the pro forums. Where are you getting this 50% more efficiency? Is there a formula I missed?
  2. #28
    chicago suburbs
    ..he's pulling it out of his a$$.
    no formula.
  3. #29
    Long Beach, CA
    Quote Originally Posted by kamikaze126 View Post
    When a heater is able to raise room temperature in half the time because of an improved ducting system you have increased the system efficiency and energy savings by 50%.
    Brian
  4. #30
    Long Beach, CA
    Quote Originally Posted by tinner73 View Post
    no formula.
    The formula is: temperature change divided by energy consumption. Are you keeping up, or should I dumb it down?
  5. #31
    Feb 2007
    Great Lakes Region
    and you feel the room temp is being raised in half the time due to pulling down the hot air from the ceiling instead of it eventually mixing on its own?
  6. #32
    Saint Joseph, MI
    If the funace cycles half as long... is it cycling twice as often?
    Unless you've altered the heat loss properties of the structure, you will still need the same BTU's to heat it. The savings would be from distributing heat more evenly allowing a lower setpoint to be used and reducing temperature swings.
    I read several papers thsi morning regarding duct design and all menton that while it's optimum ot have a high return for cooling and low return for heating, ultimately return placement has a relatively small impact. As the pro's on this board have said, it's the velocity and mixing affect of the supplies that heat the home along with in large part conduction. A return won't pull air down from the ceiling or draw air from across the floor. A supply however CAN do this.
  7. #33
    Long Beach, CA
    Yes, because it typically does not mix on its own.
  8. #34
    Feb 2007
    Great Lakes Region
    so... the heat stays at the ceiling for too long, resulting in a 50% loss because no matter how well the house is insulated it can only hold back the ceiling heat for so long?
  9. #35
    Quote Originally Posted by Brian GC View Post
    I've made them out of ply and MDF but this one is strictly temporary to prove a point. It will be removed in a few months. BTW, although it slightly restricts inflow, it is still a major improvement.
    Brian
    Go to Hart&Cooleys website.
    Download their catalog, and engineering sheets.
    Altering the return as you do, is a cover up. It covers up poor distribution selection.
    It actually proves the importance of proper supply grille/register selection.
    In this area, we use floor supplies and floor returns for both heating and cooling.
  10. #36
    Long Beach, CA
    Let me clarify further. Warmer air near the ceiling is not “pulled down”, it naturally descends do to the floor because the colder floor air is being removed. Inversely, if the warmer air near the ceiling is being removed the opposite will occur. As the warmer air is removed, the colder floor air will naturally rise or occupy more space.
    Trying to mix all the air to eliminate stratification is a pipe dream. Lowering a return to get the most out of your heater is step one, trying to mix air is the band-aid for improper ductwork.
    The reason the Pro defends ceiling returns is because:
    They are easy to install.
    They are unwilling or unable to explain the benefits of floor returns on heaters.
    They do not want to do the extra work for limited compensation.
    Their competition is not bidding for that work, so they won’t.
    The architect and GC regularly do not demand it.
    They may not know what a dual duct system is.
    They are trying to keep the price down.
    But rather than face these realities, it is easier to just point to a ‘Manual’ or a magic supply register.
    Like I said before, I’d love to take the money from any Pro who would bet me.
    Brian
  11. #37
    More like, GC's won't pay for it.
  12. #38
    chicago suburbs
    you've gotta post a pic of your revolutionary invention.
  13. #39
    NC
    I like motoguy it is all about the BTU's
