Page 1 of 6 123456 LastLast
Results 1 to 20 of 105
Thread: Introducing the Sporlan SMART Pro/R Service Tools
    Apr 2016
    It's here! The Sporlan SMART Pro/R Service Tools were developed to make diagnostic readings faster and simpler. The best part of the products might be the way they calculate and store the recorded data plus they are hose-free and wire-free.
    SMART Pro/R Service Tools automatically calculate Superheat and Subcooling with an extended bluetooth range antenna. The free app connects 10+ wireless sensors for multi-circuit systems and operate at -40 degrees. The sensors will mount to any line size allowing you the freedom of using them on any diameter pipe.
    For more information visit www.sporlanonline/smartpro.
    Name:  SMART Pro Hero.png
    Quick reply to this message Reply
    On a bull named Foo Manchu
    Anybody see a price for these?
    dealemd
    where can i buy it near annapolis maryland
    Apr 2016
    Your local Sporlan Wholesaler should have pricing within the next couple of weeks.
    Mar 2016
    Pahrump, NV
    What happens if multiple technicians are working on different systems within wireless range?
    How can sensors that are not part of your system be disabled/ignored?
    It's an upside down world we live in.
    Apr 2016
    Quote Originally Posted by David Goodman View Post
    Sporlan SMART Pro/R sensors utilize a broadcast signal mode. Once the sensors are configured, any compatible device within range will be able to communicate with the sensors via the SMART Pro/R Service App. This allows multiple technicians to view the system simultaneously. To allow for custom configurations, each sensor can be configured #1 thru #20. Temperature sensors can be configured as T1 thru T20. Low pressure sensors can be LP1 thru LP20. High pressure sensors HP1 thru HP20.
    One suggestion for a multi-system job site would be for each tech to configure their sensors 1-7, another 8-14, and a third tech 15-20.
    All sensors can still be read by any technician, but you'll know which ones are yours. The app then allows you to establish "Calculations" based off of specific sensors and subsequently RENAME each calculation with a simple left swipe.
    If a user does not want to see specific sensors that are within range, simply go to "Settings", then select "Setup", then tap on the sensor you want to remove. Tap again and a menu will popup allowing you to "Stop Using as T#". Choosing this will simply hide that specific sensor from your "Sense" list. It can be added back into your list later by following the same "Settings" path, but choosing "Use as T#" in the popup menu.
    Additionally, to protect sensors from being renamed during a technician's data recording, all sensors utilized for the recording become unavailable to all other users.
  7. Likes mr.charles, ksefan liked this post.
  8. #7
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by Sporlan View Post
    Excellent! Thank you
  9. Likes mr.charles liked this post.
  10. #8
    Oct 2005
    Why are the Straps so Cheap.
  11. #9
    Apr 2016
    Quote Originally Posted by hvactech80 View Post
    The straps work great to hold the footing of the sensor to the pipe. You can use any type of strap method you want. We included standard quick release zip ties with the temperature sensors as an easy dependable option.
  12. #10
    Jan 2010
    I have been testing thease for 2 weeks now and they work amazing just as good as the iconect but more geared towards refrigation. There is a lot that can be done with this system.
  13. Likes Sporlan liked this post.
  14. #11
    Couple of questions on the Pro/R version of the Smart tool
    Anybody have a link to the app they show in the sales stuff for Android or is it the old app?
    Do the new pressure sensors read below 0 psig?
    What does the temperature sensor pad look like where it makes pipe contact (pics)?
  15. #12
    Apr 2016
    There currently isn't an android app for the SMART Pro/R. We will have the android version developed and released in the Jan/Feb time frame.
    The SMART Pro/R pressure sensors are not intended to provide vacuum readings. The low pressure sensor range is 0-300 psig and the high pressure range is 0-700 psig. Bringing either of the sensors into a vacuum will not harm them, but they will not provide a reading.
    Here is the pic of the contact pad.
  16. #13
  17. #14
    Jan 2010
    What's the update on the Android app.?Also are there ever going to be PDF reports where we can enter start up data or unit data along with graphs and superheat pressures and temp . Also is there ever going to be a way to assign temp sensors for discarge line temp and be able to calculate discarge superheat
  18. #15
    Apr 2016
    Quote Originally Posted by kevincompass View Post
    The Android version of our SMART Pro/R app is expected in early February. PDF reports are currently available on the SMART Pro/R mobile app for iOS. (Android to follow)
    As a technician begins a new "Job", a .pdf report is automatically being built. Startup notes may be entered before the record button is touched or during the recording of a "Job".
    The .pdf will automatically include the users selections of refrigerant type and altitude. Temperature and pressure sensor readings as well as calculated parameters such as Superheat, Subcooling, Temperature Delta, and Pressure Delta can be added to the pdf report at any time during the recording of a "Job".
    This is done during a "Job" simply by going to the "Sense" screen or "Calculate" screen and touching the sensor or calculation you want added as a graphic snapshot into the .pdf. Graphs of live data or previously recorded data can not be added to the .pdf at this time. Users can choose to take a screen shot of the graphs and provide to the customer if required.
    As in the original SMART Service Tool app, the user can also export the complete set of data in ".csv" format and graph the data using common spreadsheet software.
    Our existing SMART Pro/R temp sensors have an upper limit of 230 deg F. Even though the materials that contact the surface will withstand higher temperatures, the limitation exists due to the batteries and wireless circuit components. As compressor discharge temps may exceed the 230 deg F threshold, we do not currently offer a Discharge Superheat calculation in the SMART Pro/R mobile app.
  19. #16
    Jan 2010
    It would still be nice to be able to list discharge line temp in the ccv file for troubleshooting even if they are only good to 230 . Also Oa temp would also be nice to list on the ccv as well for reports . The only real complaint iam hearing about thease is the pricing it seams to be all over the board from supply house to supply house .
  20. #17
    Jul 2010
    napping on the couch
    What's the difference between this set and these?
    [B][SIZE=2] CENTER]I no longer identify as a conspiracy theorist. You may now refer to me as “That guy that was always right”.
    “What one generation tolerates, the next generation will embrace.”
    ― Definitely said by John Wesley
  21. #18
    Aug 2015
    Buffalo,NY
    The set with the antennas is longer range. Geared more towards refrigeration work. Has lower temp ratings etc. I believe also you can link up to 20 devices together while running the app. But you buy them all separately. Their are spec sheets for each kind on their site.
  22. Likes Sporlan liked this post.
  23. #19
    Apr 2016
    Quote Originally Posted by Brian8383 View Post
    The SMART Pro/R tools have 10x the range of the original SMART tools. Also the SMART Pro/R tools are designed for use in refrigeration applications as well like MetalMan 0880 had stated. The sensors can be applied to any diameter pipe and not limited by clamps like the originals.
    You can find more information on the SMART Pro/R FAQ or by visiting www.sporlanonline.com/SMART.
    Form 140-495 Smart ProR FAQs.pdf
  24. #20
    Any updates with this?
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
