Page 7 of 7 FirstFirst 1234567
Results 79 to 84 of 84
  1. #79
    Apr 2016
    That is cool. Love the customizable options. Can a user give a name to sensors to identify them?
    When a new sensor is turned on, it needs to be cofigured with a simple number such as “T1” or“T2” for a temperature sensor. Similarly it would be“LP1” or LP2” for a low pressure sensor, etc. When the new sensor is turned on, a new sensor indication will be shown in the app sensor screen. Touch this indication to configure. Once cofigured, any mobile device that has the SMART Pro/R Service Tool app will be able to view that sensor with its given name.To change the cofigured name, use the sensor setup screen accessible in the app settings.
  2. Likes kamersoutdoor liked this post
  3. #80
    Quote Originally Posted by Sporlan View Post
    However, due to the extremely low usage of the simulated analog display on the original mobile app, we chose to go digital only on the SMART Pro/R app.
    I've been using them for over a year, and completely forgot that there was even an option for a simulated analog display.
    I'm not sure why anyone would even want it, but I started dabbling in digital gauges in 1996, and haven't use an analogue refrigerant gauge since 2005.
    Even my recovery/burnout gauges are digital.
    Other than for recovering refrigerant, I barely ever even use a manifold anymore.
    I have used a vacuum tree on my pump since 2006, and have been seriously considering building a "recovery tree" for my recovery machine.
  4. Likes Sporlan liked this post
  5. #81
    Jan 2010
    Would be nice if there was a Delta p under the calculation tab and an oil pressure measurement.
  6. #82
    Hey Mark
    I've thought about the recover set up too.
    Dont forget about the discharge to the tank. Short and big as possible.
    Was thinking of a stand that used a few inches of copper and used the recovery machine fan to draw cool air through a box around the tank.
    Only problem is I don't think my scale will work too good with the whole contraption vibrating on top of it
  7. #83
    Quote Originally Posted by kevincompass View Post
    There is a Delta P calculation.
    Click the + on the upper right when you are in the calculations tab.
  8. Likes kamersoutdoor liked this post
  9. #84
    Hey Mark
    Duno about the short pipe between the machine and the tank.
    I use a coil of copper, in a small ice chest, between my recovery machine and the tank.
    Air cooling the tank does next to nothing.
    Much of the reason I would like to build a "recovery tree" is to make something that will screw directly onto the the inlet of my G5 Twin when I remove the fitting to access the screen, and utilize a 5/8 or 3/4" flare connected filter drier so it isn't pulling through a tiny 1/4" flare filter drier.
Tags for this Thread
