Results 14 to 26 of 36
01-13-2009, 09:01 PM #14
- Jul 2008
- 550
01-13-2009, 09:01 PM #15
0.1" for the 5" under the same test conditions as the 1" which was 0.27. Big difference!
My 5" cabinent is horizontally installed on the return drop so I could easily use a 1" if I choose to. The 5" seems to have a better (lower) pressure drop as well as more effective at removing dust.
Can you post pics of your system. The guys here are pretty sharp and usually pretty accurate at eyeballing a potential high static situation.
Key1
01-13-2009, 09:04 PM #16
01-13-2009, 09:15 PM #17
- Jul 2008
- 550
I'd like to, but I'm not sure I have room. When facing my furnace, the return comes down the left side of the furnace and 90's into the bottom on the left side. Above the 90 it is 10.5"x24" and after the 90 it is 16x24. The vertical section is about 3.5" from the left side of the furnace and about 5" from the gas pipe and water heater.
The trunk can't be moved any farther left due to that water heater and gas pipe, if I had to guess. I don't know if the vertical section can be made 14"x24 instead of 10x24 due to the closeness to the furnace.
I think my only hope is one of those elbow cabinets that angle the 5" filter, but I don't know how much less pressure drop there will be if only a new filter is put in and not a bigger trunk.
01-13-2009, 09:32 PM #18
01-13-2009, 09:59 PM #19
- Feb 2008
- Dallas & Longview, TX
- 627
01-13-2009, 10:04 PM #20
01-13-2009, 10:08 PM #21
I like the idea of having the bottom and side utilized for return air. Unfortunately my unit has a big 5 ton coil sitting on top of it and once I throw in the plenum there would not be enough heigt in the basement to have the unit on a platform. I guess I could mount it horizontally
Interesting that you are using ply-wood as your return plenums.
Any humidity issues in your area?
Key1
01-13-2009, 10:12 PM #22
- Feb 2008
- 627
01-13-2009, 10:15 PM #23
- Feb 2008
- 627
01-14-2009, 10:10 PM #24
I was reading the attached links tutorial on air filters and they seem pretty knowlegeable. They seem to get it at least and they are in you area. I'm sure they would be a lot cheaper than having Beenthere take a weekend to drive all the way out there to KC
http://www.lacool.ws/index.html
Checkout the "homeowners tutorial" section on air-filters.
Key1
01-15-2009, 08:57 AM #25
- Jul 2008
- 550
01-16-2009, 07:36 PM #26
- Jul 2008
- 550
. If you are going to do it...then do it right...
