    Jan 2002
    i moved this here from residential
    view from underneath in the r/a section
    see the 1 1/2" drain pipe? from above!
    gas vent
    i took the front panel off and set it to the left side of the furnace... and it went "clang" as it hit the slab!?!
    1 & 1/2 year old house. note the 2"x4" covering about 1/2 the 7" gap in the furnace base. also note the the fine craftsmanship of expanding foam to stop a leak where the vent passes thru the jack (prolly the same dude)
    i was in shock (cust is a friend). he told me "my filters never need changed"
    [Edited by Boss on 12-28-2003 at 09:56 PM]
    Oct 2002
    Inspection?
    Amazing what you can do with a hatchet.Certainly not hvac work.
    Northeast Ohio
    I guess that's what they mean by "rough-in".
    DEM
    Lima Ohio
    The savings on filters doesn't help much against the added fuel cost though !! This site has given me a much needed laugh, thanks!
    Aug 2000
    Under my tree
    Re: Inspection?
    A hatchet? I was at the York warehouse and this guy has 3 chainsaws in the back of this pickup. Pickup has flex hangin over the sides, empty R22 bottles, etc. I ask him about the chain saws? He told me he can rough in like a 2400 sqft house in less than a half an hr with the chainsaw. Somebody goes through before him and lays out the spots, then he just rips em out with the chain saw. I guess thats what they mean by hacking the job in!!!
    To much work with too little time!!!!
