Results 14 to 26 of 34
    burlington county n.j.
    have had them about a year, no problems so far.
    i have so many sets of gauges it's not even funny!!
    heck i gave a good friend of mine who is in school and trying to get into the field, i hooked him up with a couple sets of Y/J 41 series mani's and liquid filled gauges with low loss hoses
    Jul 2005
    Dog House
    Upgraded to a Testo 560-1 4 manifold unit last summer - lasted about a month before problems. There's a pressure relief built into front that started leaking. Returned unit under warranty. Testo gave me a 523 "loaner" to use. Haven't heard back from them on update yet. They said vendor who made relief went out of business and they haven't found a replacement vendor yet. Liked it until it failed. Like 523 but want a 4 manifold.
    Nov 2002
    Ontario, Canada
    Purchased YJ Brute in summer love the 3/8 hose for pulling a vaccum. Only buy YJ most suppliers have gaskets instock when you need them.
    Jul 2005
    Quote Originally Posted by slapdash View Post
    The Brute manifold I have weighs in at about 50 lb. I use it for decoration. Might come in handy as a weapon too. If you got knocked down with that thing you wouldn't get back up. I had an old belt drive vacuum pump one time, I think it was lighter than the Brute. Yes, of course I'm talking about the original Brute, not the new one.
    houston, texas
    Quote Originally Posted by hvacrmedic View Post
    I have one of the original Brute 4 ways and you are correct they are hefty. They are on their 2nd rebuild still kicken.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    lol a weapon.
    my old service manager has a set of those things lmao they not only are heavy but the look real cheap and dorky or maybe it was him that made them look dorky
    Kansas City Metro Area
    I like the YJ's 2 valve for simple use... but those digital sure sound interesting. (Counting pennies)
    Does the 3/8" port really speed up vacs for residential with shraders in place? I can see how it would work great on refrigeration with service valves...
    Nathan
    Also I've recently bought a micron gage... with a 2 valve gauge set how does everyone put the micron gauge in line? a T? short hoses?
    The guy I learned basically used his gauges to put in refrigerant. I'm trying to make amends.
    Jun 2001
    Northwest Indiana
    Just pick these up, should be OK
    If you cant fix it right, try again.
    Oct 2008
    New Jersey
    Quote Originally Posted by toptech View Post
    I have a set of those two ports like yours, i love them. I also bought a set of high and low side NRP glycerin filled gauges, way better than the stock ones IMO.
    I dont install leaks, i just fix em
    Sig line removed by Admin*
    Lets see if this gets removed..............
    Jul 2005
    Quote Originally Posted by NathanVanKCMO View Post
    Nathan
    If someone were to loan you the YJ (Digi-cool) digital gauges for a month you wouldn't want to give them up. I was a huge skeptic not too long ago, until I bought a set. You get it in your mind that it doesn't do anything analog gauges don't do. That may be true, but what the analog gauges do, the Digi-cool does better. Easy to read, superheat and subcooling in real time at a glance, and despite being able to calculate superheat or subcooling yourself, you realize after being able to just see it on the display that it really was a PITA doing it the old way, and might I add, never being sure of the accuracy of your superheat and subcooling readings. Also, seeing these values change in real time speeds up charging time. How many times do you find yourself calculating these values using analog gauges, during a single service call checking or adjusting the charge? I realized that it was a bunch when I no longer had to do it. Keep saving those pennies.
    Oct 2006
    Emerald Coast, FL 30.1N 85.8W
    YJ & Imperial 4 valves
    YJ Titan & Brute II 4 valves, and I also use an Imperial 4 valve.
    YJs are better with easier reading guages, forged body, and the hook doesn't come out like the Imperial.
    If I were to buy a digital, it would be a YJ.
