Thread: 2 Stage Thermostat Needed?
01-04-2009, 09:54 AM #1
New Guest
- Jan 2009
- 2
I had a TRANE XL 80 (2 stage furnace) installed recently. However, the installer said that there was no need for a two stage thermostat because the trane automatically runs on two stages. I had another guy look at it and said there is no way the TRANE can run on two stages unless you have a two stage thermostat. Who knows where to find the truth? THANKS!
01-04-2009, 12:15 PM #2
it should run on first stage and then a timer will switch to second stage.
if you want to utilize the benefits correctly ...get a 2 stage stat.
01-04-2009, 12:20 PM #3
- Jan 2009
- plains
- 35
It can be set up to run on a single stage stat. The first stage typically runs about 12 minutes before bringing on the second stage. If you want tighter temp control, you will need to use a 2 stage stat.
01-05-2009, 09:27 PM #4
New Guest
- Jan 2009
- 2
Thanks guys for your help. I now feel comfortable that I know what to do.
- Joe, the Furnace Guy
01-06-2009, 06:44 PM #5
If you want the true benefits of that 2 stage furnace, you want a 2 stage stat to control it.
