Install a t-stat and LLSV.
Use pressure control for pumpdown only. Set is quite a bit lower. Only to prevent operation in a vacuum.
She will run.
I dont do any refrigeration but i was asked a question, i dont have many details but any help would be appreciated. Walk in box with outdoor c/u,R-12,pressure switch operating control cuts in @34#, cuts out@19#, maintains about 42*, cch is good. Problem is when it gets cold outside ( below 20*)box satisfies , pressure never gets above 19# to cut comp. back in. Box temp continues to climb and comp does not come back on until outdoor ambiant goes above 20*, any help would be appreciated and sorry in advance for sketchy details.
She will run.
Educational forums are open.
Thanks for the quick response, i was thinking along the same exact lines but needed a confirmation. Have a great new year.
FYI Starting point for R-12 Cut in / Cut out 36 & 16.
Remember the rules: Refrigerant migrates to the coldest point, Warm Moist Air Migrates to a cool dye enviroment.
With that said:
Refrigerant migrates to the coldest point. CCH is keeping it from condensing to a liquid in the crank case but the receiver / discharge line / condenser are still at ambient. ( Including the cylinders )The LP control senses this. As others have said, T-Stat with LLS valve is the only cure & Reset LP control as a safety only.
R I P Icemeister
Supporting our Vet’s
http://www.soldierride.org/
http://www.woundedwarriorproject.org/
How is the head psi controlled?
Not what it use to be
I havent seen the set up yet, so i dont know how the head pressure is controlled , all the info that i have was related to me by the tech. who set it all up. Ill relay what new info i have and hope it works.
R I P Icemeister
