    May 2008
    Central NJ
    Confused braze/solder, again?
    Ok, Im sorry I just post this a couple days ago:
    http://www.hvac-talk.com/vbb/showthread.php?t=189635
    I appreciate the replies, but at the same time it seems no one digested the line that said...."I got a question, beyond the obvious ways to solder/braze"...
    Regarding copper2copper. I know the best way. I've used the best way. Unfortunately at this juncture i cannot afford the equipment for the best way (i am a student).
    This is not the question.
    The question is, is mapp alone, such as a bernzamatic, good enough for soldering? for brazing? I know the peak temp is just under/at where it needs to be for brazing, and if it takes 5 minutes for flow i dont want it, that is why i ask.
    Also, i "discovered" this butane powered torch-which i had never heard of, and wondered had anyone used one like this?:
    http://doitbest.com/Propane+Torches+...sku-301462.dib
    at a local store, and at peak/adjustable flame of 2500F seems like it should be able to handle smaller, say, 1/4"-5/8" copper2copper brazing, at least to someone like me with no practical brazing experience outside of a classroom, but certainly the temp is there, the only question is the size of the area of the hottest point of the flame and how much of a variance there is from the tip to the nozzle. But then I'm the student, and this is why i ask questions
    In a perfect world i would just have my own rig, and someday i hope i do. I'm not looking for a replacement for the proper way of doing it, i already know that.
    Thanks,
    Foggs
    It isn't so much temperature as a combination of temp and BTUs.
    Mapp - air will braze, propane - air will not.
    If you want a cheaper rig to fool around with, get a MAPP/Propane - Oxygen rig from Bernzomatic.
    I did not care for the setup, but I can say that it did work. It will set you back a lot less than a full oxy-acet rig.
    I doubt that little butane torch will do much good. Sorry.
    May 2008
    Central NJ
    thank you
