Gas companies pushed them really hard in the 60's and 70's. They are absorbsion chillers and not a typical condensing unit. When the TStat called for cooling the Servel took a while to produce chilled water so hence the delays.
The thermostat actually lit up a burner(s) inside the Servel, which heated up the chemicals inside the sealed chamber that caused the cooling effect. Once cooling started there was also a small chilled water pump that pumped the chilled water to the inside cooling coil. So the lines run into the home should be water lines and not refrigerant lines.
Two big problems. Sometimes while operating or sitting over the winter the salt brine and the other chemicals would separate and a technician had to go through a process to get the thing to cool again.
Second problem is the design temp of the chilled water was not as good as a DX system in removing humidity. And most of those systems, including the large commercial ones, were sold and installed on the East Coast where humidity is a big part of the comfort picture.
The complications and the initial install costs pretty well did them in.
If you find any technical info, pictures or sales brochures a few of us on this board sure would like to see them.
- Alexis de Toqueville, 1835
