Page 1 of 5 12345 LastLast
Results 1 to 13 of 65
    Dec 2008
    80 Ton Chiller, Compressor 1 FAILURE
    Hello,
    I have a Carrier 30 GTN 080 -920. It gives me the T051 alarm. This is the manual description. When chiller is started, fan starts, after a few seconds I get this annoying alarm, so Circuit is shut down. Any Ideas? This is the manual description
    ALARM/
    ALERT
    CODE
    ALARM
    OR
    ALERT
    DESCRIPTION
    WHY WAS THIS
    ALARM
    GENERATED?
    ACTION TAKEN
    BY CONTROL
    RESET
    METHOD
    PROBABLE
    CAUSE
    T051 Alert Circuit A, Compressor 1
    Failure
    Compressor feedback signal
    does not match relay
    state
    Circuit A shut down. Manual High-pressure or loss-ofcharge
    switch open, faulty
    control relay or CPCS
    board, loss of condenser
    air, liquid valve closed.
    Jul 2005
    south
    Did you check the possible causes that the manual listed?
    Dec 2008
    Quote Originally Posted by licensed to chill View Post
    "High-pressure or loss-ofcharge
    switch open, faulty
    air, liquid valve closed."
    What does it mean "loss of condenser air"
    thanks
    Denver, CO
    Failure
    state
    switch open, faulty
    After reading this I would look for open saftey, but I'm only speculating I would have to actually look at the unit to make a proper diagnosis. It could be one of many things that would give you this error code.
    Dec 2008
    Condenser AIR?? what does it mean?
    Denver, CO
    [quote=crised;2082921
    thanks[/quote]
    Condenser fan's not running or a dirty condenser coil. Either one of these two things will cause high head pressure.
    Dec 2008
    ok, thank you!!! Very easy acctually
    Dec 2008
    How can I test the pressure measurer device, that signals to the electronic board??
    Denver, CO
    This Page intentionally left blank
    Denver, CO
    Quote Originally Posted by crised View Post
    Sorry, but I have probably already said too much this is not a DIY site and if I say anymore Hey Bob will have me cleaning coils and boilers till this time next year. In order to check pressures on the system you must have an EPA certification.
    Apr 2003
    nyc
    You have to order in a special device.
    Houston, TX, USA
    Hello,
    ALARM/
    ALERT
    CODE
    ALARM
    OR
    ALERT
    DESCRIPTION
    WHY WAS THIS
    ALARM
    GENERATED?
    ACTION TAKEN
    BY CONTROL
    RESET
    METHOD
    PROBABLE
    CAUSE
    Failure
    state
    switch open, faulty
    I have had quite a few with the control relay for the feedback signal go bad. Usually they are the ice cube style. The feed back signal is in VDC and low voltage about 5VDC if i remember correctly. When the relay goes out you will get intermittent failures. To fix problem I replace the relay with a heavier duty style. The ones I use are the brown switching relays. Have had no more intermittent failures. If you try testing the old ice cube relay you might think it is working properly since coil ohms out good and you can hear relay energize and get continuity across contacts but it is vibration when the fans come on that cause a momentary open in contacts. So pick up a cheap switching relay and save you the headache. I do remember another post citing that carrier had a repair kit for this problem but it is a lot more costly. By the way I forgot to mention I did place some gauges to rule out anything on the refrigeration side.
    East of big city prices.
    You might need an upgrade call Carrier.....LOL .They will hook you up .
