Results 1 to 13 of 21
12-28-2008, 02:06 AM #1
Sporlan Reciever Bypass Valve Info
I'm looking to see if anyone has the sporlan bulliten for a particular valve i need info on. I tried to find it in the Literature section on Andy Scohen's site and didn't find it, and I just finished a 17 hour day so i'm not going to even attempt the parker site now
The valve in which I speak and I apologize for being vague, but this is a 3 way valve in the condenser outlet (drop leg) after the flooding valve. It's purpose as far as i Can tell is to bypass the receiver to take advantage of extra sub cooling in low ambient conditions. Totally self contained/controlled, ie non electronically controlled surge valve.
it looks sort of like a normal sporlan 3 way with the exception of a pilot actuator thingy that had a Tx valve like power element which senses drop leg temp it also uses suction pressure, discharge pressure and a pilot line sensing cond out pressure.
I've only seen one of these valves before on a couple other racks of the same age. Canadian built Hussmann circa 1998
BTW if you're familiar with this valve what do you see when the power element cap breaks off
, stuck in bypass??
MikeSig removed by mod. G-Rated site
12-28-2008, 03:13 AM #2
Here's the old site.
http://sporlan.jandrewschoen.com/Merry Christmas
12-28-2008, 06:21 AM #3
12-28-2008, 08:48 AM #4
I was skim reading. Saw parker and got andy's site.
Sorry.Merry Christmas
12-28-2008, 08:56 AM #5
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
12-28-2008, 09:42 AM #6
It sounds like you're referring to what Hussmann called the "Auto-Surge" valve.
I found a mention of it in Hussmann's SuperPlus Manual, which is linked to in the EF (under "discontinued"):
http://www.hvac-talk.com/vbb/showthread.php?t=163158
...or here's the direct link:
http://www.hussmann.com/docs/inst_ma.../SuperPlus.PDF
(See Fig 2-16 on p. 29)
If it's a Sporlan it's probably an OEM special, so Andy Schoen will be along shortly to ID it for you.
12-28-2008, 09:54 AM #7
Thanks Ice, I knew you allways have all the links
I'll have to read the links later to see for sure, I'm kinda rushed now I gotta run to Buffalo, got tix for the Pats/Bills game, I just got back from the store to see if it was running OK and hopefully it's not going to bother my co worker who is covering my "on-call" while I'm at the game
But auto sounds right, I was calling it a Mechanical Surge Valve?? lets hope its not discontinued or just a proprietary hussmann valve??? if so looks like I'm going to pull the guts and do a little ball valve magic hahaha
as you can see by my 1st post and 2nd that's just a little showing of how much sleep I'm on in the past couple days
Raise your hand if you love neglected supermarkets!!! hahahahaha
12-28-2008, 10:03 AM #8
Go Bills
My Jets need HELP
12-28-2008, 10:06 AM #9
You're welcome.
Enjoy the game.
Go Pats! (I'm originally from the Boston area)
12-28-2008, 06:10 PM #10
I'm sure this is our valve... a 3-Way valve with essentially a TEV pilot. We called it a Y977-1 as I recall. I'll post additional information about it when I get back to the office tommorrow. It's been obsolete for some time, and I wouldn't have any information on it on my site.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark. – Michelangelo
There are powers inside of you which, if you could discover and use, would make you everything you ever dreamed or imagined you could become. – Orison Swett Marden
Education is what remains after one has forgotten what one has learned in school. – Albert Einstein
12-28-2008, 06:24 PM #11
Thanks Andy!
What a cold game, I was up on my feet and jogging in place at times, burrrr, long live Ralph Wilson Stadium!
See that play at the end of the 2nd???? total BS!!!!!
12-28-2008, 10:38 PM #12
From the Hussmann pdf(thanks again ice)
The valve fails to bypass mode, to reverse this you have to put suction pressure to the port that gets discharge pressure normaly and that will push slider to the normal mode via equalizing pressure, from drop leg.
would it be better to open valve and remove slider and valve off surge line by the ball valve thus removing all pilot lines, or would you think that may cause more problems?? I think that is what I'd prefer to do.
I'll just need to get a new set of seals to do this, and I'm thinking a seal kit from a normal 3 way valve may work, the body looks to be very similar.
12-29-2008, 09:01 PM #13
Forcing the system into surge mode should resolve the problem. The bypass mode was an energy saving technique.
I seem to recall we used the 8D, 12D and 16D 3-Way reclaim valves with the Y977-1 pilot. I'll try to remeber to look this valve up tommorrow. AndyThe greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark. – Michelangelo
