12-27-2008, 12:51 PM #1
New Guest
- Dec 2008
- 2
Honeywell Trusteam leaks and floods
I just bought and had installed by a licensed contractor a Honeywell TrueSteam HM506A.
Think its a 6 gallon whioch may not be enough for a 3,000 sq ft house. But its working fine except for one very important aspect. In the 5 days we've had it the fresh water feed into the unit, its a thin pipe through a small connector keeps leaking furiously to the point where the garage fllods. The contractor has been back and tried to fix it. We get it working and cycling OK then all of a sudden it bursts a leak.
The connector design looks very unreliable to me.
Thoughts appreciated
12-27-2008, 12:59 PM #2
Is he using one of these.
http://www.waterfiltersonline.com/de...Self_Tap_Valve
If this is what leaking? I would suggest having him install a tee in the line and a reducing fitting.
If its the other fittings have him replace the fitting instead of tightening them, the threads are probably stripped and they will never hold.
12-27-2008, 05:33 PM #3
New Guest
- Dec 2008
- 2
Honeywell Truesteam
No its a white 1/4" compressed thread.
It has a little black ring inside it which looks wholly insufficient to hold the pressure.
12-27-2008, 05:41 PM #4
Have your contractor call his HW rep. It's a known defect.
Merry Christmas
