Twilli says read manual, there in contains your answer grasshopper
Have a RHEEM (Weather King) LP furnace that we just installed set inlet at gas valve 11" wc and outlet 6" wc, runs all day and at night when temps are (-2 to 8 degrees F) furnace locks out on "loss of flame" Any ideas... This one is kickin my rear! Thanks & Merry Christmas!
No Heat No Cool You need Action Fast
I did read manual set them correctly hoping to see if anyone had experience with propane and pressure issues to due lower ambient temps. Thanks
Can't recall seeing a Rheem that uses 6" for LP.
You know I thought the same thing Manual ask for 5-6?? I just was hoping for some direction... Thanks Anyway
How big a tank? Above ground?
I believe a 300 gal tank above ground
Well, it doesn't seem as though you have a vaporization problem, as long as the tank isn't empty.
With Twilli usin them numbers as a guide, Christmas ain't never gettin here it be 10.5 forever
DEM
Lp kit installed ? what's the model and s/n ?
Not a 2 stage is it? Simple enough, actual orfice hole size determines the firing rate per orfice at the provided pressure x # of orfices needs to = the firing rate of the equipment
DEM
your gas pressure is too low for LP.
I think someone is giving you the answer
Twilli says nooooooooooo way even though its Christmas and even if its about 10-10.5 degrees we don't give out that kind of information.
LISTEN to twilli and you will be PREPARD!
Incase anyone is keeping track. This really bugged the SH^* out of me and I went out yesterday (Christmas Day) to work on this kids were done opening presents and it was to cold to do anything else. Anyway I set the valve to 10" even and and still the same problem, Found the old tank Regulator on old tank replaced the reg and the son of a gun took off.... noooooo problems. Thanks guys for all your help!!!!
Glad to here you fixed it. Now, get your post count up so you can upgrade your status. That way, Tilli won't have to give his knowledge out in code!
DEM
Agreed go ahead and post up. Even if you're a tard We can assume pro
