Results 1 to 13 of 13
    Oct 2008
    Lennox Heat Pump Snow Cover Picture Request
    Anyone have a picture of what the install manual refers to a "top cap snow cover" for the Lennox xp19?
    This is my first winter with the heat pump and after a large snow fall, the blades were completely covered, since the top of the unit is just a flat grille. I am worried that the snow may turn to ice and wear out the motor prematurely.
    The "top cap snow cover" seems like the solution, but I cannot find a picture of what it looks like anywhere.
    Jun 2006
    New Jersey
    Wow I thought the XP19 had a plastic cover with side oulets, just like the Trane XL line. You sure its a XP19, I have never seen one with just a flat grill on it.
    Myrtle Beach, SC
    I would not put anything on top of the unit. At outdoor temperatures that allow snow, the outdoor unit should be running, which usually blows the snow off before it can settle on the outdoor unit.
    I have seen several unit covers. I have found that with the cover on, more air is recirculated so the efficiency is reduced. Also, the outdoor fan motor draws more current, since any restriction adds load to a propeller fan motor. This shortens fan motor life.
    Stay away from the caps.
    Remember, Air Conditioning begins with AIR.
    Myrtle Beach, SC
    Quote Originally Posted by ascj View Post
    I have an XP19. It just has a flat grille on top. I have never seen the Trane top on anything but a Trane.
    N.E. Ok.
    I thought a
    was one of those goofy covers sold for a/c condensers that homeowners forget to remove in the spring
    Link to what appears to be a winner[URL="[URL="http://toronto.kijiji.ca/c-buy-and-sell-home-garden-Air-Conditioner-cover-for-External-Home-Air-Conditioning-Unit-W0QQAdIdZ92645042"[/URL]"]
    Oct 2008
    Quote Originally Posted by Kevin O'Neill View Post
    The outdoor unit should be running, which usually blows the snow off before it can settle on the outdoor unit.
    I have calculated my transition point between gas and electric to be 20 degrees. There are plenty of times here when it snows that it is below 20, and therefore the HP is not running.
    Oct 2008
    Quote Originally Posted by captube View Post
    I thought a was one of those goofy covers sold for a/c condensers that homeowners forget to remove in the spring
    No I imagine it to be a plastic cap that looks like the trane permanent cap, with a hard top and vents on the sides, and would need to be removed before running it in cooling mode.
    burlington county n.j.
    i saw the reference to the "snow cap" in the install instructions but nothing about it in the engineering book or the service notes.......
    could be something were the paperwork has not all been updated, have your installer contact lennox tech support and see what they say.
    it cannot be a cover just for the winter because the heatpump still needs to move air in the heating cycle.
    Mar 2002
    Richmond, Virginia
    Catalog # X8782. The drawing shows what looks like an open wire box 40"x36"x11-1/2" that has a solid top so that the air discharges through the sides.
    There is nothing more frightful than ignorance in action....Mark Twain
    Oct 2008
    Quote Originally Posted by HVAC Pro View Post
    This seems like what I was looking for. Thanks for the help.
    Oct 2008
    Received a quote from my dealer on part X8782. $320 +tax! Seems a little expensive for a wire box.
    Do you have access to pricing information? Just want to make sure he priced the right part, since they did not even know that this existed.
    Mar 2002
    Richmond, Virginia
    We can't discuss pricing here, but I will tell you that that is quite a bit lower than the suggested retail price.
    Mar 2002
    Richmond, Virginia
    And the description is: For applications in high snow load areas-Painted to match unit-heavy gauge steel-welded wire grid. Fits XP19 2 thru 5 tons.
