Results 1 to 13 of 13
    Dec 2008
    Angry acont800 American Standard thermostat - HELP!
    I have an American Standard thermostat model acont800 hooked up to my American Standard furnace/heat pump and the fan is running way too much. The thermostat fan mode is set to auto, and the fan even continues to run while heat pump is in defrost mode which blows very cold air out of registers. It has done this since the time of installation, and after several HVAC men in the are and many dollars later, everyone agrees it's not right but nobody can seem to fix it. Does anyone know how to make an adjustment so fan will not run in defrost mode? Thanks in advance!
    pittsburgh,pa
    You need to check installers setup at tsat . Similar to honeywell vison pro model will need the installers guide to accomplish this. An American standard dealer should be able to rectify problem if other tech is troubled
    Nov 2001
    Seattle, WA
    Having the indoor supply air fan run during defrost is normal if there is a call for heat. That is not where your problem, lies most likely.
    Their should be additional heat source provided during defrost to temper the homes supply air. If not, that is where the technicians need to focus on problem solving.
    Call another HVAC company first and ask them over the phone why this may be happening. If they don't mention that you should have another heat source available during defrost then you should move on to another company that understands the operational sequence of a heat pump during defrost.
    - Alexis de Toqueville, 1835
    MN
    It has to run in defrost mode, they need to wire it so back up heat kicks on also. Pretty simple really, if they can't figure it out they need to call tech support to figure out which wire is missing.
    You can't fix stupid
    MN
    Delta beat me, but the answer is the same
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by jwiehagen76 View Post
    the set-up on that or any other t-stat won't allow a user to shut the indoor fan down on defrost!
    pittsburgh,pa
    I was just saying it may not be set up correctly. Although in this area heatpumps are used as a last resort. defrost should kick in aux heat i would imagine. Not tryng to a smart a$$
    May be service one or two a year. Oil /natural and Lp are the most common here.
    Do you have an air handler with aux electric heat.
    Or a gas furnace.
    Dec 2008
    air handler w aux heat
    central america
    x2 from outdoor unit not landed at indoor unit. How does unit react in emeregcy heat mode?
    Dec 2008
    Confused
    When we turn on emergency heat, it runs just fine. This unit is in a new, small, very well insulated house. When it is set on emergency heat it doesnt run very often at all and the house holds constant temp. However, when the heat pump is on, after the warm air is done blowing, and the house is up to temp, we start getting very cold air from the registers which makes it very uncomfortable, and thus starts calling for heat again. Hope this helps.
    central america
    You have control wiring issues, contact your local Trane/ american standard dealer.
    Yep.
