Results 1 to 6 of 6
Thread: Backdraft Dampers
    Dec 2008
    Backdraft Dampers
    I am going to be adding a solid fuel furnace in my home> I have an exsisting lp forced air furnace that I will be keeping. I am thinking about adding backdraft dampers, one in each furnace in order to isolate each unit. I have worked out the diagram and located theunits,either Honeywell or Aprilaire, both of which are motorized.
    What I am thinking of is to install 1 at the top of the exsisting plenum which will be "normally closed" . But will open when the solid fuel unit is down and the LP gas unit calls for heat.
    Am I going in the right direction?
    Thanks,
    Tom
    Quick reply to this message Reply
    Jun 2008
    Southeast Michigan
    1. Read the forum rules: NO DIY
    2. If you are licensed, apply to become a pro-member and post this in proper forum.
    3. Thread is probably going to be locked soon
    4. IBTL.
    Back draft dampers should be weighted/barometric, not motorized.
    Thats all I'll tell you.
    central america
    Are these dampers to isolate ductwork, suppy air? Or isolate vent products of combustion?
    Dec 2008
    This is to isolate the lp furnace while the solid fuel furnace is operating.
    Thanks Superheatman!
    Jun 2001
    Louisville, KY
    Perhaps you should have read the instructions before calling.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
