Results 1 to 4 of 4
Thread: Fireplace Gas valve help..
12-14-2008, 10:48 AM #1
New Guest
- Dec 2008
- 3
From what I can find I have a 710 series robertshaw 750 millivolt gas valve. its a 1/2 1/2 straight through low profile high low valve . I am lookin to replace it with something current .. The only label thats on it is ..
60034s NAT 1"-4" WC MAX 1/2 PSI.. .. Has anyone seen these before?
12-14-2008, 11:05 AM #2
New Guest
- Dec 2008
- 3
dexon industries has one that is similar
12-14-2008, 02:44 PM #3
forum move
This needs to be moved to the Fireplace Forum.
You should get a fireplace pro to inspect the fireplace and perform the work. You can replace the valve only with one from the mfr. approved for that unit. Non-OEM parts will void the warranty and listing and is unsafe.Keep the fire inside the fireplace.
12-14-2008, 03:30 PM #4
New Guest
- Dec 2008
- 3
thank you I will
