    Dec 2008
    Fireplace Gas valve help..
    From what I can find I have a 710 series robertshaw 750 millivolt gas valve. its a 1/2 1/2 straight through low profile high low valve . I am lookin to replace it with something current .. The only label thats on it is ..
    60034s NAT 1"-4" WC MAX 1/2 PSI.. .. Has anyone seen these before?
    Dec 2008
    dexon industries has one that is similar
    S.E. Pa
    Exclamation forum move
    This needs to be moved to the Fireplace Forum.
    You should get a fireplace pro to inspect the fireplace and perform the work. You can replace the valve only with one from the mfr. approved for that unit. Non-OEM parts will void the warranty and listing and is unsafe.
    Dec 2008
    thank you I will
