Results 79 to 91 of 108
Thread: If you have alerton questions
10-29-2011, 08:12 AM #79
New Guest
- Oct 2011
- 2
username localadministrator // Password = ??????
What is the username localadministrator default password and if it has been changed to something other than the default, is there a way to change it back?
10-29-2011, 05:24 PM #80
The password could be anything and is set the first time you launch ebt after installation. You would have to backup ebt, uninstall ebt and reinstall ebt(if you have a software disk). Launch ebt after reinstalling and use any password you want. If you dont have a software disk you are hosed. You could try using localadministrator as the password or the local reps company name.
What is not performing properly?
Alerton will only offer support through a dealer.
10-30-2011, 04:06 PM #81
- Dec 2008
- Seattle WA
- 63
A disturbance in the force
Obiwan, Please contact Alerton, and ask for the regional sales rep for your region, contact him/her and tell them your concerns. While they don't have direct control of the dealers, they can exert some influence on them. I don't think they want Alerton delaers acting like this.
You bought the system, you should have any level of password you want, including the ability to restrict the Dealers access if you choose.
08-13-2012, 08:57 AM #82
New Guest
- Aug 2012
- 4
Hi
I have just been asked to engineer an upgrade for an old Alerton system. So far I have found they have an 'Envision for IBEX' head-end, an APEX LT and a number of TUX field controllers downstream of this.
My first hurdle which I have stumbled on is trying to create a basic points list for each controller on the site (or at least all the points used by the supervisor) as there is zero documentation on site, no panel wiring diagrams and no cable numbers!
I assume each IBEX point used on the head-end is created within the APEX and from there, linked to an TUX and channel reference.
My question is - could you tell me how I would go about back engineering these IBEX points to determine their controller & channel? Or is there anyway of exporting a table from the Envision to show this information?
Any help would be much appreciated!
Cheers
10-30-2012, 01:17 PM #83
New Guest
- Oct 2012
- 2
I'm having trouble getting BACtalk server to talk to the controllers. How does the server find the controllers exactly? I know it runs off the UDP port 47808, but how does the server see it? Is it a unicast or multicast?
10-30-2012, 01:26 PM #84
- Dec 2008
- Seattle WA
- 63
"I'm having trouble getting BACtalk server to talk to the controllers. How does the server find the controllers exactly? I know it runs off the UDP port 47808, but how does the server see it? Is it a unicast or multicast?"
Not sure, you should not need to know that level of detail; perform a Device Scan, you should see controllers. Since the Server rides on Ethernet, usually the Ethernet based controllers come in first, followed by the MSTP controllers.
What type of controllers do you have on the same network as your server? Are you seeing some, or none? What version of Alerton software are you using?
First thing to check:
Look at the header at the top of the Envision for BACtalk window - does it say "(offline)"? If so, your software is not seeing the license key.
10-30-2012, 01:31 PM #85
- Dec 2008
- Seattle WA
- 63
There is not really a simple way to pull points out of an Ibex system.. You really should contact the installing dealer and ask them to provide you a copy of the installation wiring diagrams. That will get you all the physical points.
If you hire an Alerton Dealer to do the upgrade, they will do all the design work for you,and they are proficient in digging in and finding this level of information. But this time, be super strict about getting all your documentation before you pay them retention on the project.
They have a BCM-Tux device that will allow you to simply replace the front end and global controller, putting your system in a much better condition, for a lot less $$ than replacing the whole thing. The downstream controllers are likely in good shape, and will last you a very long time.
Good luck,
John
10-30-2012, 02:47 PM #86
New Guest
- Oct 2012
- 2
It was installed by a by a dealer and the dealer is unable to get the controllers to connect to the server which is on another subnet at another site. Does this work via unicast, multicast? How does the server discover the ethernet controllers? Broadcast? It doesn't have any options to look for the device via IP. I have other sites connected to the BACtalk server that reside in a different subnet, and this just recently happened where you could no longer see the missing site. We have cleared the path of anything that could be stopping the 47808 traffic, and the server still does not see the 47808 traffic. Routing works. We can ping the device IP from anywhere on the network.
I just want to know how the network side of this system works. Just plugging it in and knowing it will work does not do it for me. All licenses are up to date and version is, Envision for BACtalk 3.0 (Build 0025), and it is online. I can adjust other HVACs at other sites.
10-30-2012, 04:05 PM #87
- Dec 2008
- Seattle WA
- 63
Lol - your dealer needs to send you a more qualified guy. Alerton has an internal network design guide that the dealer has access to; this plus Alerton's Dealer Tech Support should be able to help even the newer guy get your problem resolved.
Here's some basics on how it works:
Your server should be speaking BACnet IP. ( technically, BACnet IP is UDP/IP) One of the Alerton globals in the SAME subnet as your server is set up as a BBMD (Bacnet Broadcast Management Device) and also speaks BACnet IP. One Global controller in each subnet is set up as a BBMD, and the BBMD's pass all the data that needs to go from one subnet to another. They basically act as routers, keeping local data from passing and passing data that other subnets require. Each BBMD has a table in it listing the IP Addresses of the other BBMD's in the BACnet network. It's super solid communications, and it restores itself after power fails or internet interruptions, etc.
BBMD's today conform to "Annex J", the latest revision of the BACnet standard relating to BBMD's and such.
BBMD setup can be a little tricky, as there are setups for private Annex J, and public Annex J, depending on whether or not you will be traversing the internet, and the two need to have different UDP ports.
I can't tell you what these values should be, as it can all be set up in a hundred ways and still work.. Your dealer should be able to produce a network map for you that shows all the nodes on the Ethernet, including the BBMD's and their settings. If memory serves, everything inside the subnet should share the same UDP, and all the BBMD's share a different UDP. Don't quote me on that - I usually whip out the design guide myself when I am setting up a network.
As far as messaging goes, I believe that BACnet is multicast inside the subnet, unicast through the BBMD's.
Good Luck!
John
10-31-2012, 11:23 PM #88
- Jan 2011
- Bartlesville, Ok
- 96
I will review a little bit.
47808 (BAC0 in hex) is the default/suggested port address, but not mandatory. It might be something else. Another subnet might have already had another bacnet system in place using 47808 and the dealer just decided to use another port for the entire system.
It is possible for the server to be communicating via Bacnet/IP OR Bacnet Ethernet. So, it is possible the comm method was changed inadvertently.
The global controllers are configured using a null modem connected via Hyperterminal in Windows. Some will have a switch of some sort to enable the config connection. On the BCM-Eth the 232 port is inside the cover. You can take a laptop to the local global controller and connect via hyperterminal to see the actual configuration including IP address, subnet mask, port address, etc. That way you know how you should be communicating.
With a lower security level you may not be able to change the configuration of the server.
I am with those that believe if the warranty is up, the dealer should not be able to hold the owner out of the system. I would see what the courts have to say about that.
10-31-2012, 11:54 PM #89
- Dec 2008
- Seattle WA
- 63
01-14-2013, 12:08 AM #90
- Jan 2007
- 729
Anyone know the differnce between a VAVi-SD and a VAV-SD? I'm thinking the i was one made as an OEM for Krueger VAV boxes, but mayne someone could shed some light on this for me.
01-14-2013, 06:49 AM #91
- Mar 2008
- Council Bluffs, Iowa
- 72
