Page 3 of 26 FirstFirst 1234567891013 ... LastLast
Results 27 to 39 of 333
  1. #27
    Dec 2008
    Dallas, Tx
    Quote Originally Posted by mechinc View Post
    OK...I put the subroutine in bldg A BCM
    I put the heartbeat in bldg B BCM
    It seems to work but I have 1 issue.
    I see the heartbeat with BV 30.
    Then I removed the power to bldg B BCM
    As the BCM is powering down BV 100 switches to
    show comm fail but once the BCM is completely
    powered off, BV100 switches back to normal.
    Is this correct?
    Ok well when the bcm that has bv-100 is off you should get an unreliable reading because the bcm it references is off.
  2. #28
    Quote Originally Posted by ph33r View Post
    I believe I setup the BV as off=normal, on= comm-fail
    So when it goes completely offline, the BV stays on Normal.
    If I can get it to go NR, is there a way to flag the NR
    and email that out?
    Also,
    I noticed whomever setup the programming performed
    all logic in visio and are using BVs and AVs.
    Why would one use the global BVs / AVs when you can cut down
    network traffic by using the local device's logical BIs /AOs
    This way all logic is in the local controller and the only thing that
    is going through the global is OA-share, etc.?
  3. #29
    Dec 2008
    Dallas, Tx
    and email that out?
    Also,
    I don't know maybe they were doing a global process such as determining the lowest cooling signal and reseting a chiller? There could be many reasons, now if they wrote basic code like hot water valve control or vfd pi loops then that doesn't make sense.
    There is no way to monitor and dial out if your bcm-eth craps out as it is your connection to the net. You could have a dedicated vlc that monitors a point from the bcm and have a bo connect through a relay to a modem that has terminal blocks to monitor alarms but that is allot of work.
    Unfortunately if the bcm goes well your sol in MOST cases.
  4. #30
    Is there a way to flag NR?
  5. #31
    Jan 2010
    Hi All, I have been reading through the previous postings relating to Bactalk but have not seen any topics relating to removing of staff from the alarms. Here's my predicament:
    My Data Centre manager has retired, I have removed him from the SMS alarms but he but is still receiving the Voice alarms.
    Can somebody please explain to me how to remove his name from the Voice alarms? I am using Envision BACtalk V1.30A
    Geordie09
  6. #32
    Mar 2009
    VB
    Georgie , Check your post....
    Ph33r, Sorry beat you to it
  7. #33
    Dec 2008
    Dallas, Tx
    Hehe, well I got the BCM-TUX one :-D
  8. #34
    Hi Ph33r and other experts,
    I am new to Alerton. What programming software from Alerton I should use/purchase, if I only use Alerton field controllers with non-Alerton BACnet frontend (say, Niagara AX)? Thanks!
  9. #35
    Aug 2009
    England, UK
    Quote Originally Posted by leaflying View Post
    I am new to Alerton. What programming software from Alerton I should use/purchase,!
    Hi All, I have a similar question - I have some used/removed Alerton controllers, including an 'IBEX' hardware lock. Rather than dump the lot, I was interested in learning about the programming/software routines, etc.
    The Alerton product is quite rare in the UK due to the Honeywell tie in with other products, so getting any information is not easy.
    Many thanks.
  10. #36
    Dec 2008
    Dallas, Tx
    You will need envision for bactalk to develop the graphics and frontend and the ebt will come with the visio macro for programming or you could use the blue screen in the ebt program. Alerton is one of the easiest programming langauges I have found. This is all BACtalk Ibex is a different beast.
  11. #37
    Dec 2006
    What? Who? Where?
    ph33r,
    Would you happen to have any technical documentation on the LSI?
    I am also looking for the latest ROC files for it as well.
    My email is in my profile.
    Thanks.
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
  12. #38
    Mar 2009
    VB
    Email sent>>>>
    ph33r , I hope you dont mind, I dont want to over step my boundries...
  13. #39
    New Hampsha'!!!
    Quote Originally Posted by berg2666 View Post
    Having to change graphics for a new controller and chaging user privs and passwords but getting an error stating "Sharing Violation" and "DB Error"
    Bactalk 2.3 front end with Alerton BTI's and Alerton devices in two buildings, Delta Controls devices in another building with one FEC, Delta Controls devices in another building.
    The graphics need to be changed for the one device were a delta DAC was taken out and FEC installed.
    Do not have any manuals except the two boardsmoker sent me recently.
    LTBT-TM-PRGRMR and
    now I can not find the other
    can i get a copy of whatever he sent you?????
