    Clear RAM and Reset
    What effect will it have on Tracer Summit if I do a clear Ram and reset on the BCU.
    I have a Precedent series rooftop with a Diag: SA Temp sensor Fail and am trying to reset it and it will not clear. Reliatel control board.
    All overrides will go back to default. Chiller Plant Control and other apps will take a while to get back to normal.
    I wouldn't clear ram and reset to often, if you continually have problems and doing this fixes it then you need to troubleshoot what the underlying cause is and fix that.
    Thanks Scrooloose,
    I did the reset and saw that everything did go back to default.
    Thanks for the quick answer to my question.
    Jul 2001
    maryland
    That diagnostic is being generated by the RTU not the BCU. You need to reset the rooftop.
    Feb 2007
    True Dat nothing to do with the BCU,replace your sensor and be done with it
