    Getting a Code 31 Error with Induced Combustion Furnace
    Okay--I checed the blinking LCD and get a Code 31 Error, which says to check for a number of things but I think its this:
    Defective Pressure swith or connections. The reason I say that is because right after that, it says, "If it opens after trial for ignition period, blower will come on for 90 second recycle delay."
    Now that's what happens with mine. If I reset the door switch (i.e., just push in the switch that would be pushed in if you put the service access door back on), the heater comes on for 90 seconds and then shuts off. This problem was intermittent for a couple days--the heater would come on later at night, but now doesn't come on at all.
    Is there any way to check for that/fix? If I need it a repair, what should it cost?
    SE Michigan
    No pricing questions and no DIY advice....ya gots to read the forum rules Zeek.
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    Quote Originally Posted by coolwhip View Post
    Sorry--you can go ahead and delete the post.
    kpmccaff pe owner
    very common error/code many possibilitiesrobably best to haxe unit serviced/evaluated by an authorized dealer;service tech having exp. with your particular model.
    Lancaster PA
    Thread closed.
