+ Reply to Thread
Results 1 to 17 of 17
Thread: What is this?
    Phoenix,AZ
    What is this?
    Old hussman 502 freezer. The canister on top of the accumalator with the bolts and psi tap, is it a removalable core suction line filter/dryer or is it something else?
    Illinois
    Looks like a filter/drier from where I'm sitting
    Nov 2005
    I also agree on a filter drier
    Western NC
    you got it buddy...
    I installed one of them once.....
    Its a filter dryer. All of em are mounted vertically like that. Just like an oil filter on a fuel oil system.
    Why do you ask? Somethin wrong with it? Or are you just verifying your assumption?
    Feb 2007
    Northern Ontario
    Talking filter drier
    makes for easy removal of drier core block inside.. you can simply pump down unbolt top (there is a spring in there) and replace core.. usually added where you know you will be changing drier a couple times...Burnout etc...there are actually different cores to put in 1 for acid removal.,, etc
    You miss 100% of the shots you don't take...
    Phoenix,AZ
    Quote Originally Posted by iraqveteran View Post
    you got it buddy...
    No, nothing wrong with it. I did work on it a while back and at that time i was like "what the heck is that". Now that i have a decent camera phone and i was there yesterday working on something else. I decided to take a pic and see if you guys thought it was a suction dryer too.
    Looks like a Superior to me.
    Apr 2008
    I'm sure those cores are more expensive than a sweat drier but it sure beats hauling your torches on the roof.
    Could be an Alco or Henry also...Can be used with suction type filter or dryer cores can be used, (fine mesh screen a must) after a burnout. Best way to get the acid and moisture out of mid sized conventional units. The liquid dryer core and oil can be changed a couple times along with your liquid line dryer, then replace liquid core with suction filter or no core at all.
    Guam
    Quote Originally Posted by moe663 View Post
    Yes they are more exspensive but most of the customers I have dont' complain, what they spend extra for the core they save in labor, dont' have to lug torches to the roof and is much faster to changeout in my opinion.
    Love makes the world go around but cash pays the bills
    Philadelphia
    Yes they are much more convenient when piped properly with isolation valves. If you have a burnout or moisture condition you can just shut the valves isolating the canister and change the drier core and pull a vacuum from the "psi port" rather then pulling the whole system down. Especially good fro compressor changes you can go back a few hours after first run time and remove the burnout core.
    Jan 2006
    In a land far, far away
    Quote Originally Posted by mark itziro View Post
    Bingo! You don't see many of those any more.
    Yea, only two stores I have serviced have em. The local supply house doesn't carry cores for them in stock anymore. Have to special order them in.
  14. #14
    California
    looks like one of those suction line hyper thrust bearings that increases the suction vapor mass flow rate to force it through the accumulator, but only during low load periods.
  15. #15
    Phoenix,AZ
    Yes, thats what i was thinking..
  16. #16
    Nov 2008
    S.C.
    that looks like the kind I saw an older tech put a roll of toilet paper in once. that was a long time ago. He put the real thing in later. Anyone ever heard of that before?
  17. #17
    California
    Only if the system is contaminated with S**T. but dont go cheap, buy the good stuff.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
