Results 1 to 13 of 17
Thread: What is this?
12-09-2008, 10:22 PM #1
What is this?
Old hussman 502 freezer. The canister on top of the accumalator with the bolts and psi tap, is it a removalable core suction line filter/dryer or is it something else?
12-09-2008, 10:26 PM #2
Looks like a filter/drier from where I'm sitting
12-09-2008, 10:37 PM #3
I also agree on a filter drier
12-09-2008, 11:53 PM #4
you got it buddy...
I installed one of them once.....
Its a filter dryer. All of em are mounted vertically like that. Just like an oil filter on a fuel oil system.
Why do you ask? Somethin wrong with it? Or are you just verifying your assumption?I fully support the military and the War on Terrorism.
12-10-2008, 12:16 AM #5
- Feb 2007
- Northern Ontario
- 128
filter drier
makes for easy removal of drier core block inside.. you can simply pump down unbolt top (there is a spring in there) and replace core.. usually added where you know you will be changing drier a couple times...Burnout etc...there are actually different cores to put in 1 for acid removal.,, etc
You miss 100% of the shots you don't take...
12-10-2008, 12:20 AM #6
No, nothing wrong with it. I did work on it a while back and at that time i was like "what the heck is that". Now that i have a decent camera phone and i was there yesterday working on something else. I decided to take a pic and see if you guys thought it was a suction dryer too.
12-11-2008, 03:37 AM #7
- Sep 2004
- 45
Looks like a Superior to me.
12-11-2008, 04:35 AM #8
- Apr 2008
- 51
I'm sure those cores are more expensive than a sweat drier but it sure beats hauling your torches on the roof.
12-11-2008, 04:53 AM #9
- Mar 2008
- 252
Could be an Alco or Henry also...Can be used with suction type filter or dryer cores can be used, (fine mesh screen a must) after a burnout. Best way to get the acid and moisture out of mid sized conventional units. The liquid dryer core and oil can be changed a couple times along with your liquid line dryer, then replace liquid core with suction filter or no core at all.
12-11-2008, 06:49 PM #10Love makes the world go around but cash pays the bills
12-11-2008, 08:57 PM #11
Yes they are much more convenient when piped properly with isolation valves. If you have a burnout or moisture condition you can just shut the valves isolating the canister and change the drier core and pull a vacuum from the "psi port" rather then pulling the whole system down. Especially good fro compressor changes you can go back a few hours after first run time and remove the burnout core.
12-12-2008, 09:52 PM #12
12-14-2008, 04:42 AM #13
- Sep 2004
- 45
Yea, only two stores I have serviced have em. The local supply house doesn't carry cores for them in stock anymore. Have to special order them in.
