Results 14 to 26 of 36
    Jan 2011
    http://www.thermopride.com/pdf/PS020002.pdf
    http://www.thermopride.com/products/...e-oil-furnaces
    Call their Warranty Dept and request records on the specific model you are interested in ?!!
    http://www.thermopride.com/contact
    I'd be surprised if they make that data available. Maybe I'll give them a call though. Thanks for the response. Given the limited number of Google hits on this furnace, I'm getting the feeling that there just aren't all that many of them in service.
    Hey I'll respond, even two years later.
    Still plugging along great. We go through about 250 gal of oil a winter for a 1200 sf house in New England, I believe that's pretty economical as oil furnaces go.
    Caveat: When we put it in, the difference in heating costs (btu to btu) for oil and gas were nearly identical. Now, gas would be about 1/2 as much. Will that stay the same? Who knows? For a $300-400 annual savings in fuel costs we're sticking with the thus far reliable Thermopride; it's a 10-15 year payback otherwise.
    If you're going oil, this furnace is THE way to go. Future economy might favor gas big time though.
    Jan 2011
    Thanks for the response. Unfortunately gas isn't an option here. I went ahead and bought the OH6 with the Riello single stage and the ECM blower. I'm just waiting till closer to the end of the heating season for the switch over.
    Nov 2008
    1/2013 update (4 years of ownership):
    Still love my Thermopride OH6 single stage Riello burner and ECM motor . I think we determined that it used just less than 700 gallons during the recent winter that we had snow form Christmas through April on Long Island (worst winter so far). During the previous year to that year when we had a very mild winter with no snow, it burned just under 600 gallons for the year (mildest winter). This is including running an old oil hot water heater (typically burns 86gal/6 mo summer when the furnace is off). When we had the original 1958 General Motors furnace, we use to burn 1100 gallons for the year so I have been super happy with my savings.
    Ddi put a steam humidifier but the house is too leaky for it to get much better than 30% RH (typically want 40-60% RH I was told). It helps but it is not perfect. I tend now to not even use it other than in Jan - beginning of March and even then I tend to leave it off.
    PROBLEMs I have had!!!!
    1. I have had major issues with servicing. First, no one carries a 0.60gal/hr 80 degr hollow cone nozzle on their truck. I have asked and pushed and some have told me they do not stock such a small nozzle in that pattern. Others say they do but end up not having it. I relinquished and went to the local supply store and purchased a couple Delevan nozzles and ask them to put that in instead. they always want me to run a larger gal nozzle with a solid pattern at 65 degr. but I am affraid it might impinge on the far chamber wall so I spend the couple of bucks for the proper nozzle. So far it has served me well so why change what is not broken.
    2. During normal servicing, they change the nozzle, oil filters (I change the duct filter - 4 inch unit) and they CLAIM to clean the heat exchanger. I say claim because if you read the install/owner's manual on the OH6, it states that it needs to have the heat exchanger annually and inspect it for cracks. No one has performed what the manual indicates. The manual says to remove the burner and the burner flange/gasket and vent pipes to access the heat exchanger to brush and vacuum it out. They also offer side ports to clean the outer portion of the heat exchanger. At most, they will vacuum out the outer chamber ports and nothing else.
    My question is if the outer chamber ports have debri, wouldn't the main chamber have debri too? Why wouldn't they want to follow the manufacturer's directions for proper cleaning? Are there any gaskets that need replacing or issues to handle?
    Currently I have Slomin's (one of the dealers Thermopride lists on their site) had come to do the annual cleaning and so far they have refused to do the cleaning as indicated in the manual. I have had others that have at least removed the vet pipe in an attempt to vacuum it out from there but that is still not enough. I called SLomin's before the service man came indicating what was needed to be done so they would send the right guy to do the job. I let them know what the manual stated. They assured me the tech would do what was necessary. When he came, he said he would not do that kind of cleaning. I called and asked the sales dept what is included in a tunep/cleaning and they did indicate that cleaning the heat exchanger was included. When I asked why they would not follow the manufacturer's directions for proper cleaning, they fell silient.
    Before you get this unit, make sure someone is willing to clean it properly. Get it in writing before you sign anything. Have them read exactly what is required. I would not mind if Slomin's would have said to me when I signed the contract that it would cost extra to service it. At least I would have known what I was getting into. I brought it up and they said it would be no problem servicing both my hot water heater and furnace. Now I am awaiting what will happen next. So far it does not look good. They told me that it would cost $$-$$ per hour labor to do the cleaning it required and that I would have to cover the hourly labor rate. This may be the last time I deal with Slomin's.
    I did contact Thermopride and ask if I could convert my OH6 to gas and they said that if I remove the Riello and put in a gas fired burner, that was all that was needed to be done. I might look into having a professional convert my furnace. Any issue with converting?
    I am not sure if a homeowner can clean the heat exchanger or not. The Riello I have is attached with 3 crews and the burner flange is attached with 4 more. Nothing else is needed to be removed as far as I can tell.
    Can someone indicate if a homeowner should or should not do this cleaning (done by a pro)? Is it needed to go to this level of extreme? What are the disadvantages if the manual is followed to the letter? Are there any?
    All I know is that I avoided buying a 95% condensing oil furnace (from Adams I think) because of the difficulty in servicing and that it was told to me that no one would service it properly causing headaches. I think I am back in the same boat. Too bad Thermopride doesn't put in some form of port somewhere to access the inner chamber for cleaning. This is its only drawback.
    Anyone know of a good oil service man who will do the proper maintenance on Long Island?
    Other than that, it has been running great.
    Frank
    Nov 2008
    Finally spoke to a few people at Slomin's and after talking with Steve there, they came to the decision that it would be easy to remove the burner flange to access the inner chamber of the heat exchanger at no additional cost. Prior to talking with Steve, Mike in sales wanted to charge me $$ an hour. Steve misunderstood from the tech what it would require and the time involved.
    Thank you Steve for helping work this all out. He is a great guy to work with and very helpful and understanding. Thank you.
    Proper tuneup has been scheduled for within the week.
    thanks
    Frank
    glad "all" is going well, never met a T-pride that was hard to clean, flange bolts breaking -yea, but not hard to clean.
    might want to speak with them about that nozzle issue, are these the guys that installed the furnace.
    Nov 2008
    Slomins did not do the install. Gelber and Sons did. They did a superb job unfortunately they only do installs and not maintenance.
    I called Thermopride back and they suggested for the OH6 that the burner flange gasket (part # 330212) will probably need replacing and , depending how hard it is to remove the cleanout ports, the cleanout port gaskets (2 x # 330215).
    Is there a universal flange gasket that can work? I was hoping to order the gasket for them to have, just in case but they will not sell it to a homeowner and so far I have not found any parts suppliers on Long Island that carry Thermopride.
    I have, via the website, contacted thermopride. I am awaiting a response. when I called, they said I could not buy it direct from them and to contact the service guys to order the parts. I did shoot Slomin's an email offering to pay for the gaskets and to get an extra one, just in case. Also, no word so far.
    I will let you know how things go. hopefully the flange bolts do not break.
    What do we do if they do break? Drill and tap or what? Should we put anti seize on them? Regular or copper color antiseize?
    I just want to offer the serviceman all I can to help expedite the job for them. they were a little concerned this would take hours to do and I want to be as prepared for them as possible or at least offer what knowledge I can so they can come prepared.
    thanks
    Frank
    they just need to be careful when they remove the taps from the studs, if one breaks there are "certain" things that can be done until a replacement clamp is installed
    heat & age are generally the culprits when one breaks.
    your contractor should be able to get the "spare" parts for you if they don't keep them stocked.
    Nov 2008
    I got a reply that they will look into getting the parts. I really do appreciate the lengths Steve is going. I hope Slomin's knows the quality guy they have. Thanks Steve!!
    Jun 2005
    SW Wisconsin
    Fly2High -Frank
    Frank, I have witnessed two Thermo Pride OL 11 oil furnaces that have been in operation for 31 years & 29 years having never had the heat exchanger cleaned; as it takes 10 foot extension brushes.
    NOTE: A one inch (outside diameter) vacuum cleaner hose will fit into the radiator. None have the necessary tools to do the job. http://www.thermopride.com/pdf/OilFiredFurnace.pdf Scroll down to the chart...
    I didn't see what GPH nozzle, was it .50? The OL6 would be my choice.
    That Riello requires 140 psig pump pressure to the nozzle; pump pressures ought to be checked.
    The lack of proper servicing is one of the things, among others, that I have against oil furnaces. Oil furnaces have a lot of critical servicing requirements that are simply not performed...it's a sad situation...
    AOP Forum Rules:
    Rules for Posting
    Rules For Equipment Owners
    Equipment Owners Find a Contractor HERE!
    Free online whole house load calculator & Sizing: http://www.loadcalc.net/ Anyone can use it...!
    udarrell
    Nov 2008
    Thanks for the comments. I had never owned a home with forced hot air and this is my first. Gas wasn't available when I purchased the home but now the line has been brought up to the neighbors house across the street. When I wanted to replace the furnace, the gas company wasn't returning my calls so I was forced to go with oil. Also, from what plumbers were telling me, it would be about $$-$$ for the natural gas. It was bad enough this was $-$.
    Now we are talking about getting a residential generator and bringing in the line. Thermopride said that we could convert the furnace to gas by swapping out the Riello with a gas burner. Would you advise against this? To me, we have already saved 2,000 gallons of oil due to the really poor efficiency (and hole in the heat exchanger) on the original unit so I am not feeling so bad about converting to gas. the only downer would be needing to replace the oil fired hot water heater as well. I need to figure out if our hot water usage would allow us to go with a gas on demand setup.
    What should be done during a tuneup on my furnace with a BF3 Riello single stage and ECM fan?
    I wanted the nozzle changed (0.60gal./hr 80deg. hollow delavan used), heat exchanger thoroughly cleaned, smoke test, CO test, draft test, stack temp and efficiency performed. Sometimes they take the duct to the chimney off and scoop out the soot.
    I will ask for the pump pressure to be checked.
    What else should be done or is this everything?
    thanks
    Frank
    Jun 2005
    SW Wisconsin
    I wanted the nozzle changed (0.60-gal./hr 80-deg. hollow cone Delavan used), heat exchanger thoroughly cleaned, smoke test, CO test, draft test, stack temp and efficiency performed. Sometimes they take the duct to the chimney off and scoop out the so
    I'll let the other Oil PROs respond to that question.
    It is always important to have the duct airflow system well sealed & checked for proper sizing for both heating & A/C; he old belt-drives when converted to A/C nearly always were way low on airflow.
    For many reasons, the Return-Air filter-area sizing .
    Yours, has a D.D.ECM 5-Ton blower; WOW...
    AOP Forum Rules:
    Rules for Posting
    udarrell
    Nov 2008
    Why leave it to someone else?
    Are we afraid to post the correct way such that another may be caught doing it the wrong way and cause a little extra work to a collegue?
    The right way is just the right way. There is no opinion when it comes to this and if someone is asked to do the right job, shouldn't they do it properly?
    Afterall, this site is not allowed for DIYers so the only reason I see is for either diagnostics, which we all know really cannot be done via postings. It needs to be done on site. the other, is so the homeowner , in this forum, knows what is the right and wrong way to maintain a furnace, get help, and to know what to ask for and to not be ripped off.
    Maybe I am wrong.....
    I cannot see the harm in posting the answer.....
