Results 1 to 13 of 36
12-09-2008, 11:22 AM #1
- Nov 2008
- 45
ThermoPride OH6 oil furnace - FANTASTIC!!!
I had a Thermopride OH6 with ECM motor and I want to throw some good press their way for making a fantastic furnace.
It is oil fired with a single stage Riello burner (2 stage is available but I passed on it)
I got the ECM motor. Love it. It comes on slowly and I no longer have a blast of cold air when the furnace first starts.
I am running a Honeywell Vision IAQ Pro and it was easy to install.
According to the oil company, it is running 87% efficient with a flue temp about 360 -380 deg (something like that - at work I don't have the actual spec)
Compared to my previous furnace which had a flue temp of over 680 deg!!! this thing is far more efficient.
I like the fact that the Riello I got with it has a port on it to hook up a fresh air input. I am concidering doing that and closing my 12" x24" fresh air vent a saving some money!
It also is very quiet - at least compared to what I had before.
It stands only 46" tall.
For the month I have had it, it has been great.
Thanks guys at ThermoPride for such an outstanding unit.
Definitely worth the money for them. Highly recommend them to anyone wanting the highest efficiency furnace without goig to a condensing coil unit.
Frank
12-09-2008, 02:46 PM #2
- Jun 2007
- The Twilight Zone
- 2,964
Good for you that heating oil prices didn't climb to over $4 per gallon which is what it was looking like this past summer when gasoline was at a record high price.
Take care.
12-09-2008, 03:10 PM #3
- Nov 2008
- 45
Not to mention that when we took out the 1958 General Motors furnace we found the heat exchanger had rusted and a hole was found in the top. We were getting some exhaust gases into the house I am sure.
then again 50 years isn't that bad of a service life....
12-09-2008, 08:19 PM #4
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
PROUDLY made in Denton NC
and that other place
in Ohio
you'll not get a better oil furnace
01-16-2009, 12:19 AM #5
- Sep 2005
- 46
We've got the same set up with the piped in combustion air and it saves on infiltration big time. Great furnace. Our net stack temp runs about 335 deg at 90.1 efficiency.
On our third year here's two things to watch for: gasket between burner and heat exchanger as provided didn't adequately seal when firing for long periods and required replacement at 2 years; and this year for the first time (just prior to annual service) the flame sensor safety punched out and required reset--bit of sooting on the electrodes that a clean and nozzle replacement (we're running .5 gph) remedied.
Agreed on the 'Pride, I keep the damned thing waxed and show it to anyone who comes over! It helps huge that we had a great installing contractor.
11-05-2009, 11:38 PM #6
New Guest
- Nov 2009
- 1
why did you select the single stage Riello burner over the 2-stage Riello?
11-06-2009, 03:37 AM #7
- Nov 2004
- SW FL
- 5,272
11-06-2009, 04:52 AM #8
11-06-2009, 07:54 AM #9
- Nov 2008
- 45
Basically, I didn't feel that heating at a slower rate was worth it for the size and conditions I have. Also, It was already getting expensive and I also felt that this is a rather new technology for a home unit. I didn't want to be a 'Beta' tester of it and see what kind of longevity it had. The single was already a proven technology so that's what I got.
Sooooo much more efficient than the old one and with how high prices went last year, i was happy to have it.
02-04-2011, 04:29 PM #10
- Jan 2011
- 7
Fly2High or Dave Davis, Any update on the performance and durability of the Thermo Pride OH6? I'm seriously considering this furnace with a Riello and the ECM blower and can't seem to get any feed back about this unit.
02-04-2011, 04:37 PM #11
02-04-2011, 05:11 PM #12
- Jan 2011
- 7
02-05-2011, 09:36 AM #13
- Nov 2004
- SW FL
- 5,272
Mfg Warranty Dept.
http://www.thermopride.com/pdf/PS020002.pdf
http://www.thermopride.com/products/...e-oil-furnaces
Call their Warranty Dept and request records on the specific model you are interested in ?!!
http://www.thermopride.com/contactDesigner Dan
