Results 1 to 13 of 25
    Airflow/ Static pressure
    What equipment do you guys use for checking system airflow/ static?
    If anybody is familiar with the score ratings for systems, the company I work for is getting into that pretty seriously. Need more tools....ive got my eye on the fluke 922.
    HVAC PRO IN THE MAKING
    NATE's:
    Gas Heat Service/ Installation
    Air-to-Air Heat Pump Service/ Installation
    Air Conditioning Service/ Installation
    Apr 2008
    Central CA
    I use the Testo 510 for most of my measurements like
    gas pressure,
    static pressure throught the systenm or individual parts like filter, coil etc,
    FPM to convert to cfm,
    Iv read it can measure draft but i havent tried it yet but im sure it would do the job.
    For draft i just started using the dwyer 460 as suggested by DavidR and weber
    Very cool tool for FPM and SP high and low for $50.00
    Central Kentucky
    Quote Originally Posted by Profiler View Post
    The Testo digital manometers or a Dwyer magnehelic both work great for static pressure
    If you are doing score you must work for an ISL member.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    from prices i seen the testo is more economical than the fluke.
    also it is the meter i use (testo)
    http://www.youtube.com/watch?v=nFl0n...ture=endscreen
    Ohio
    Testo 510....
    I need a new signature.....
    Apr 2002
    give me a magnahelic or give me a
    http://www.shortridge.com/pdf/ADM-870C.pdf
    http://www.ductstrap.com/
    what do you guys use for tubes with that testo 510? its a differential meter so can it read single imputs?
    NATE's:
    Ohio
    Yes it can read single inputs....I keep mine in the tool bag and use it check gas pressures also....
    I have been using the same hoses that came with my Dwyer Magnahelic...
    clear vinyl tubing found at any hardware store
    Chicagoland
    Quote Originally Posted by stomper56 View Post
    I tried it on an 80% while my analyzer was on the 2nd unit, no luck! The analyzer said .04-ish.... must be out of range.
    Im still up in the air about this one. I like the fluke better but the challenge is trying to catch one on the bay for less money. The testo goes for $160 but the flook looks cooler
    do you guys just drill holes and shove the tube in there to get the static or do you guys actually use a pitot tube with it? I think I need more input/recommendations to sway me toward testo as ive not used any of their stuff yet and use all fluke. Also does the testo read in negative pressure for return static?
    NATE's:
    Chicagoland
    A pitot tube is for velocity, static pressure tips are for static. Dwyer makes a variety I like the A303, it has a magnet on it.
    Chicagoland
    A differential manometer has two ports, one is positive and one negative. Either port when left open will reference atmosphere (or"0" pressure).
