Results 14 to 20 of 20
    Alabama
    Quote Originally Posted by jeepgrady View Post
    Thank you for those words of wisdom. Your assistance is greatly appreciated.
    <<<See that?? This means I'm kidding, OK?
    But now I'm not - Nobody on here is going to tell you how to fix it yourself. Call a reputable company in your area. They won't have any problem with this.
    Lehighton, Pa.
    That's my problem. I can't seem to find a reputable company in my area. I don't pretend to know enough to even attempt to fix it myself. I'm just looking for some clues to pass the info on to the latest company that has been to my home. They told me that the system is working as designed which obviously is incorrect.
    Yes, the problem was fixed about a week after that post. The replaced the wiring harness and defrost board and if relative humidity is low, it will run up to 6 hours without defrosting. Ask your company to replace both of those to see if it works. Good luck!
    Lehighton, Pa.
    Both were already replaced. Same problem occurs.
    Could be caused by an incorrect charge also.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by rlj1117 View Post
    the defrost t-stat does not know there is no frost on coil
    do you not know what demand defrost is not?
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by yankfanof2 View Post
    at 28 you shuld be going to gas...
    you sure about that chief?
