Results 1 to 13 of 32
    Jun 2007
    Bucks Co PA
    Negative chimney draft -oil furnace
    I recently had a complete new system installed; Carrier heat pump and variable speed oil furnace 58VMR. I notice oil furnace exhaust fumes in the basement when the oil furnace runs.
    Because it is a duel fuel system, the oil furnace does not run that much until the outside temp gets to about 30* or below.
    I called the company that "hooked-up" the oil furnace (the install company does not do oil) and the fellow found a negative one draft from the chimney. He is puzzled by this situation. When the oil furnace runs for a few minutes the draft is positive as it should be.
    The oil guy said to "just run the oil furnace only".
    It seems to me that it would be "natural" to have a negative draft in a "cold" chimney. Am I correct ??
    If that IS the case how do I prevent "exhaust fumes" in the basement ?? Any suggestions ??
    BTW, I just had a contractor (other than the ones associated with the install) seal the duct work as best he could.
    Northeast Ohio
    + = pressure = no draft = oil fumes
    DEM
    Aug 2008
    Ask him what -.04 is and what it means to him.
    Oct 2002
    Yo.... Here!, I'm right here..
    No
    cold chimneys don't draft naturally warm ones do..........I don't think you should be seeing a "positive draft" at all anywhere....anytime with a resi system such as this.......
    Hey get an Oil guy in there to set it up, just pay them or buy their service contract and their oil, it'll only make things safer for you and your famly.......... or did you get the cheapest price and are willing to gamble your family's life.............
    Your oil guy that was there. Is not thinking clearly, to say the least.
    The flue and chimney should both be in negative draft when the furnace is running, or you WILL get fumes.
    Jan 2006
    Powell River, BC, Canada
    Some oil furnaces like the Carrier have a + OVER FIRE draft usually around +.01". All oil furnaces should have a - FLUE draft of -.02 to -.04".
    Where are you? Are you done yet? I got ONE more call for you.....
    Jul 2005
    Jack2007; do you have a "barometric" damper installed onto the vent pipe to the chimney? if so, is it set up right?
    If not, get one and have it set up by a pro to neutralize any positive/negative pressures.
    Settings are normally .03 to .02 w.c. using a draft gauge, also have the pro check stack temp.... usually 450 * (+ - 40*)
    Altmar, New York, United States
    Quote Originally Posted by gasguy View Post
    YES, BUT YOU STLL NEED A NEG DRAFT AT BREECH.
    Jun 2007
    Bucks Co PA
    Thanks to all for replies.
    Rlattime3 Ask him what -.04 is and what it means to him.
    This on the receipt;
    "smoke pipe and overfire has down draft +.02 breech, +.02 overfire....fumes coming out draft regulator.........ran burner draft was -.04 breech, -.02 overfire.............draft good immediately after burner shuts off"
    Roscoe
    No
    I had a highly recommended HVAC company (recommended by a pro on this site) do the install.
    beenthere
    OK. When he said "negative draft" he meant cold air coming down the chimney when the furnace was NOT running.
    deejoe
    Yes there is a "barometric" damper. The guy who came said every thing except the draft (cold air coming DOWN the chimney) was normal.
    Oct 2002
    This sounds normal.... -.02 O.F. and -.04@breech
    .......are you saying that it lights off hard initially, then runs fine and then the draft #'s are good. Or better put HOW does it light off.........
    Jun 2007
    Bucks Co PA
    Quote Originally Posted by Roscoe View Post
    All I know is there are fumes in the basement.
    The oil guy is the one who believes cold air should NOT be coming down the chimney when the furnace has been off for a while.
    The contractor who sealed the ducts (but does not do oil), made a comment that maybe I should look into having the barometric damper AND furnace air intake vented to the outside.
    Oct 2002
    No barometric....??
    Ya definitely need a barometric......as stated above by deejo
    Jun 2007
    Bucks Co PA
    There IS a barometric damper.
